01-10-2012, 08:24 PM | #1 |
Blue halos
Do ya'll know if blue halo rings are illegal in Texas?
01-10-2012, 08:39 PM | #2 |
Drives: 92 Camaro Convt RS,2011 Camaro RS Join Date: Mar 2009
aren't they all illegal in texas.
TEAM LLT 1992 Camaro Rs Convertible 2011 Camaro 1lt Rs |
01-10-2012, 08:44 PM | #3 |
All colored halos? That would be disappointing
01-10-2012, 09:18 PM | #4 |
yea blue light's are more for law enforcement knowing them easy ticket for you.
01-11-2012, 10:46 AM | #5 |
God Bless Dawson
Drives: Synergy for my Daughter Join Date: Feb 2010
We have a DPS Officer in the HTCC club. He says the only halos illegal to use on the road in Texas are red. He has blue on his camaro.
You can't have your halos blinking while on the road.
01-11-2012, 11:00 AM | #6 |
Account Suspend...Right
Drives: Synergy LS & Vulcan 1600cc Join Date: Apr 2011
In Ohio I read the laws and Blue and Red are illegal, and it doesnt say anything about other colors, But I run my greens all day with no problems. And, if I get a ticket ill just pay it and keep running them.
01-11-2012, 11:19 AM | #7 |
Drives: 2012 Camaro SS2 Join Date: Dec 2011
Hope this answers your question (from Texas Motor Vehicle code):
Sec. 547.302. DUTY TO DISPLAY LIGHTS. (a) A vehicle shall display each lighted lamp and illuminating device required by this chapter to be on the vehicle: (1) at nighttime; and (2) when light is insufficient or atmospheric conditions are unfavorable so that a person or vehicle on the highway is not clearly discernible at a distance of 1,000 feet ahead. (b) A signaling device, including a stoplamp or a turn signal lamp, shall be lighted as prescribed by this chapter. (c) At least one lighted lamp shall be displayed on each side of the front of a motor vehicle. (d) Not more than four of the following may be lighted at one time on the front of a motor vehicle: (1) a headlamp required by this chapter; or (2) a lamp, including an auxiliary lamp or spotlamp, that projects a beam with an intensity brighter than 300 candlepower. Sec. 547.305. RESTRICTIONS ON USE OF LIGHTS. (a) A motor vehicle lamp or illuminating device, other than a headlamp, spotlamp, auxiliary lamp, turn signal lamp, or emergency vehicle or school bus warning lamp, that projects a beam with an intensity brighter than 300 candlepower shall be directed so that no part of the high-intensity portion of the beam strikes the roadway at a distance of more than 75 feet from the vehicle. (b) Except as expressly authorized by law, a person may not operate or move equipment or a vehicle, other than a police vehicle, with a lamp or device that displays a red light visible from directly in front of the center of the equipment or vehicle. (c) A person may not operate a motor vehicle equipped with a red, white, or blue beacon, flashing, or alternating light unless the equipment is: (1) used as specifically authorized by this chapter; or (2) a running lamp, headlamp, taillamp, backup lamp, or turn signal lamp that is used as authorized by law. (d) A vehicle may be equipped with alternately flashing lighting equipment described by Section 547.701 or 547.702 only if the vehicle is: (1) a school bus; (2) an authorized emergency vehicle; (3) a church bus that has the words "church bus" printed on the front and rear of the bus so as to be clearly discernable to other vehicle operators; (4) a tow truck while under the direction of a law enforcement officer at the scene of an accident or while hooking up to a disabled vehicle on a roadway; or (5) a tow truck with a mounted light bar which has turn signals and stop lamps in addition to those required by Sections 547.322, 547.323, and 547.324, Transportation Code. So, unless they flash or are over 400 candle power technically they can be any color. Now, for officers actually knowing the Texas Motor Vehicle code enough to know that you are NOT in violation??? I would not take the risk and just stay away from any colors other than white or yellow. Sure a cop runs a color on his, but he wont get a ticket even IF he is stopped. You probably will and will have to show up in court and have the prosecutor prove a code that does not exist. Sure, you will probably get off, but you wasted a day for each time you get pulled over. |
01-11-2012, 11:22 AM | #8 |
More on my previous post. Technically they are illegal in any color. Code specifies that the vehicle can only have 4 lights total on the front of the car. Running lights with head lights is 4, head lights with fog lights, 4; so halo, head and any of the others would be in violation. Chances are you wont get called on it though since they are surronding the headlight.
01-11-2012, 02:41 PM | #9 | |
God Bless Dawson
Running halos on since March of 2010 and never pulled over. I have had officers controlling traffic come over and shake my hand and ask where I got the nice lighting. I gave them business cards and tri-folds for AAC. lol
01-12-2012, 10:49 PM | #10 |
www.Camaro5store.com
From a police officer, YES. They are illegal when used ON THE PUBLIC ROADWAY. private property is fine.
01-13-2012, 08:41 AM | #11 |
Thanks for the info guys!
01-13-2012, 05:09 PM | #12 | |
God Bless Dawson
Many Officers out there have no idea. When you consider how many laws are on the books you can understand why. I'll go along with what the Texas Department Of Public Safety Officer says. More so since he runs blue halos.
01-31-2012, 06:58 AM | #13 | |
Drives: 2012 2LT/RS Join Date: Nov 2011
If it's not white or amber, I'd pull you over. |
02-02-2012, 11:12 AM | #14 |
Retarded One-Legged Owl
Drives: 2010 Black Camaro 2SS Join Date: Oct 2008
How do they define "beacon" in the context of the bolded line?
Similar Threads | ||||
Colorado members check in here | 2010 SS RS | USA - Rockies / Midwest | 8853 | 06-13-2022 07:45 PM |
How To Wire Dual Halos On Single Switch | kismyss | Camaro DIY & HOW-TO instructions & discussions | 54 | 05-06-2014 11:18 AM |
Group Buy!!! LED Headlight and Tail Light HALOS, Only $99 Each!!! | Wes@Flashtech | Exterior Parts & Accessories | 51 | 09-27-2010 08:19 PM |
Mystic Blue Twilight (2010 1LT RS IBM) | Mystic Blue | Member Car Journals | 4 | 09-26-2010 07:08 PM |
Raise our voices!! We need a 2nd Blue in 2011!! | SS22 | 5th Gen Camaro SS LS LT General Discussions | 51 | 01-04-2010 10:14 PM |
