12-29-2021, 08:56 AM | #1 |
Drives: Chevrolet Camaro Join Date: Dec 2021
Convertible Top Help
I just purchsed a 2011 convertible with 20 miles on the clock.
The trunk is empty and the trunk partition is in the stored position. I released the front latch, slightly pushed up the top and returned the latch to the closed position. I press and hold the rear of the top button and the windows go do. Then nothing happens except the sound of a motor spinning. What am I doing wrong? Thanks in advance for any suggestions. Jim |
12-29-2021, 09:09 AM | #2 | |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
12-29-2021, 03:28 PM | #3 |
Drives: 2013 ZL1 Convertible A6 BRM Join Date: Feb 2015
The partition should be pulled back towards the trunk opening. Then operate the top button
2013 ZL1 CONVERTIBLE BRM A6
OHIO |
12-29-2021, 04:01 PM | #4 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
If the 'window shade' in trunk is not in it's fully extended position, and/or the trunk is not closed, then you should see a message in the dash indicating 'the top is not secure'.
If you see that message, the top will not retract. |
12-30-2021, 07:03 AM | #5 |
All of those things could cause the top not to go down however it can't be this guy's problem. If it were the windows wouldn't go down when he pushes the button and he wouldn't hear the pump motor running. I suspect it has a leak and is out of/or low on hydraulic fluid. These things are complicated....definitely not a diy fix.
01-04-2022, 06:42 AM | #6 |
Doors and trunk closed, window shade in trunk locked in place and windows down
01-07-2022, 06:34 AM | #7 |
Drives: 2013 ZL1 Join Date: Sep 2021
Since you are a new owner of this car is it possible the previous owner used the emergency top wrench to open the bypass and never closed it???
01-07-2022, 08:19 AM | #8 |
Drives: 2024Camaro 2SS CE Convertible Join Date: Jul 2013
01-07-2022, 07:39 PM | #9 |
Didn’t think about that but is a real possibility and would do exactly what he is describing. Only question is why would that have been done?
01-08-2022, 08:59 AM | #10 |
It may have been left loose from the factory or from a previous service and slowly backed out until the top finally stopped working. May explain the car being sold in the winter???
01-08-2022, 09:27 AM | #11 |
I wonder just how many Vert owners know that there IS a bypass valve.?
I wonder how many know that the car came with the wrench for the bypass valve? I wonder how many know WHERE the bypass valve is? I wonder how many know WHERE the bypass wrench IS ?? I know mine came with the wench, Not sure where the wrench is right now (No it's not in the glove compartment any more). I know OF the valve but no idea where the darn thing is. |
01-08-2022, 11:16 AM | #12 | |
Drives: 2014 Camaro RRM 2SS RS, M6 LS3 Vert Join Date: Aug 2015
Dream it - drive it!
01-08-2022, 12:04 PM | #13 | |
Whosoever Will
01-08-2022, 12:18 PM | #14 |
