Old 02-24-2024, 11:52 AM   #1
SSChris15
Drives: 2015 Camaro SS
Afm/dod delete
In 2019 one of my lifters failed, dealer ship replaced everything car has ran fine since then, till today. Once again a lifter has failed. Does doing the dod delete help this is issue?
SSChris15 is offline   Reply With Quote
Old 02-24-2024, 01:30 PM   #2
AlisoBob
Drives: Camaro 2SS Gen 5
YES!!! All the lifters stay in the "Locked" position. I have a AFM/DOD delete module in the classified section.
AlisoBob is offline   Reply With Quote
Old 02-25-2024, 09:46 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
False.. It does not lock your lifters. The range "disabler" device just changes the tune in the ECU to tell it "disable" the AFM/DOD program for the 4 lifters, they will still function as normal lifters do, but the delete kit you inquired about contains the following, all the lifters are REPLACED. Good luck.
https://www.texas-speed.com/p-7379-t...SABEgJUYvD_BwE
Old 02-25-2024, 10:31 AM   #4
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Yes you should do definitely do the dod delete kit if you want to stop replacing those darn lifters all the time, and its a great opportunity to change your camshaft since you'll have to anyways.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 02-25-2024, 12:07 PM   #5
AlisoBob
Yes.... by leaving them locked. When the locking pins fail to fully engage, thats when you get tons of valve lash, and stuff gets all torn up.
The Range disabler keeps this from ever happening by not letting the lifters transition to the AFM/DOD position.
Old 02-26-2024, 08:24 AM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
OP, here is how the AFM in our engines work. If you do the delete, it would be a good time to do a cam swap as well. and delete the AFM/DOD in a custom tune.
https://help.summitracing.com/knowle...SR-04901/en-us
Old 02-26-2024, 08:31 AM   #7
gtstorey
You really don’t have an option on whether to swap the cam on an actual DOD lifter swap to regular lifters. The cam lobes on the DOD cylinders are different.
Old 02-26-2024, 12:31 PM   #8
cerberus_ss1
Drives: 2010 camaro ss
Yeah, a DOD delete could definitely help with your lifter issues. It's worth considering for better reliability and performance. But it's smart to chat with a mechanic first.
cerberus_ss1 is offline   Reply With Quote
Old 02-26-2024, 01:00 PM   #9
AlisoBob
Thats not how it works at all. When the solenoid opens, oil pressure is forced onto the sides of the lifter, pushing the locking mechanism's IN, which unlocks the inner lifter body from the outer.
Old 02-26-2024, 07:43 PM   #10
gtstorey
I can’t really tell much difference in what summit says and what you are saying. Maybe where the oil flows in? All summit really says is that oil flow causes the lifter to collapse. It doesn’t say by what mechanism.
Old 02-27-2024, 11:08 AM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
After digging deeper into this, I actually learned something from Mr Bob that I wasn't aware of with these lifters! They actually DO lock up with a pin and oil pressure control, I just thought it was only the oil pressure that did the work. Here is the video I found that explains it pretty well. I did though have the function of them correct, just didn't know there was a sliding pin involved.
Old 02-27-2024, 01:08 PM   #12
AlisoBob
Well, thats the goal of these forums, right? To spread good info.
By defeating the AFM/DOD you keep the lifters "Locked" and avoid the chaos that comes with a lifter lockpin failure.
(I still have a RANGE module in the classifieds..... hint, hint)
Bob
Old 02-27-2024, 01:47 PM   #13
AlisoBob
Also..... IF I ever have a L99 cam disaster, I'm for sure not going to put another hydraulic lifter cam back in. Why do all that work for nothing?
I'll step up to a solid roller deal. Just a few more parts like adjustable rocker arms is all that's needed.
