09-24-2012, 06:29 PM | #1 |
BUMBLLB
RX Catch Can Noise
Have a rattling noise coming from my RX catch can. Is anyone else having this noise and is it suppose to be making the noise? It only has about 3500 miles on it.
I know I have asked this before, but It seems to be getting worse and happening more often.
09-24-2012, 06:41 PM | #2 |
Don't Sleep on My V6
Is it always making the noise? Because it could be that your hearing the can filtering. Check the lines for leaks if you haven't already and make sure the can drain valve is closed.
09-24-2012, 06:42 PM | #3 |
Da WHALE
Drives: 2014 Stingray, 2015 Panamera 4 Join Date: Dec 2011
Mine makes a hissing sound from the breather. The can itself I get no rattling. Good luck on finding out what it is. Hopefully nothing serious.
Project MantaRay...Underway
09-24-2012, 07:24 PM | #4 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Usually if the valves are loud the drain got left open my mistake. Threads all the way out exposed is CLOSED, all the way in retraced is OPEN.
Double check (car idling place finger over the drain hose....should be no suction) and if it is to loud let me know. Hissing is the air entering the breather and as it has a flow controlling checkvalve it does hiss. |
09-24-2012, 07:50 PM | #5 | |
Here is a link to one installed to the evap cylinder, I installed mine on the other side of the evap cylinder: http://www.camaro5.com/forums/showth...light=catch+v6 |
09-24-2012, 07:57 PM | #6 |
Da WHALE
Thanks Tracy! I wasn't worried about the breather hissing. I figured that's why it's called a breather. LoL ! A few others I asked couldn't tell if theirs was hissing or not.
09-24-2012, 08:48 PM | #7 | |
BUMBLLB
09-24-2012, 08:50 PM | #8 | |
BUMBLLB
09-24-2012, 09:33 PM | #9 |
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
if it helps i have mine mounted on the engine cover stud and i hear no noises inside the cabin at all. From time to time i do hear the air sound when im outside the car and its idling
09-24-2012, 09:37 PM | #10 | |
BUMBLLB
Thanks Tracy!!
09-24-2012, 09:40 PM | #11 |
This is a common mistake! You car should perform better now that its closed properly also!
09-24-2012, 11:18 PM | #12 |
Out of curiosity can leaving the valve open on the can while driving harm the engine at all?
09-25-2012, 10:48 AM | #13 |
Wont harm it, but wont catch any oil and creates a vac leak.
09-25-2012, 02:40 PM | #14 |
that sucks
