05-19-2010, 08:38 PM | #1 |
Drives: 2010 Red SS/RS Join Date: Jul 2009
A6 tune for L99 - How good can it be?
I want to get a tune for my A6, to make the shifts firmer, reduce torque management in Sport mode and normal in Drive mode. And if I could really have my cake and eat it too, the tune would optimize engine performance in Sport mode and optimize gas mileage in Drive mode.
Now my options, as best as I know, are go to a local tuner or get a mail order tune. Both of these then have more options. So, can what I want be done with a handheld tuner? If not, then I have to go to a local tuner or maybe Vector can do it. Am I correct so far? If I get a local tune done with say HPtuners, can I store it on a handheld, so I can flash back to stock and back to the tune when I need to? Without going back to the local shop? One last question. If I flash back to stock, go to the dealer and they flash an update for say the radio or cruise control. Then I or the local tuner reflashes the tune, will the update still be there? I'm just looking for a solution and appreciate everyone's view. |
05-19-2010, 08:51 PM | #2 |
Motor Head
Drives: CTS-V Join Date: Feb 2009
The best solution for your conditions is to buy HP Tuners yourself. You don't need the Pro version for what you want to do.
History Camaro's: 83, 93, 95, 98, & 10.
05-19-2010, 08:54 PM | #3 |
Drives: 2006 Corvette Z06 Join Date: Feb 2010
Tuning for maximum power won't really impact your fuel economy, as they are two totally separate operating conditions of the engine covered by different strategies. Tweaking your transmission shift points and optimizing the activation window of AFM will give you fuel economy gains. You can see some from the engine calibration, but there's always an asterisk on that.
If somebody tunes you with EFI Live or HP Tuners, then no, you can't really store the tune and flash it whenever you want unless you buy your own EFI Live/HP Tuners cable. |
05-20-2010, 12:39 PM | #4 | |
But separate tranny tunes would be beneficial? Can HPtuners or EFI Live make a tune with with different attributes based on Sport and Drive mode? I'm a little leery of using something like HP tuners. To get good at something usually is trial and error. Its the errors I'm worried about. And I imagine that the transmission tune is even more complicated than the engine tune. I guess if I have HP tuners, then I could get an HP tuners mailorder or local tune. I could just step back and let Vector do it, but man they are expensive, at least initially. |
05-20-2010, 01:51 PM | #5 |
Tuning for power enrichment scenarios (aka wide open throttle) has absolutely no impact on your fuel economy. No, you do not need separate tunes, because maximizing WOT performance has nothing to do with your part throttle fueling or timing.
You don't really need separate transmission tunes, either. I'm pretty sure you can make normal drive tame and optimized for normal driving, and set up sport mode to be more aggressive. I haven't really dug into A6s. |
05-20-2010, 03:21 PM | #6 |
Drives: 2005corvette Join Date: May 2010
Tuning the new A6 automatic tranny is not for the novice tuner.
There is over 400 parameters with this new transmission alone. It is very easy to cause damage to this tranny if not tuned properly! We charge a little more for tuning the A6 since the time to do so is more involved with this tranny. |
05-20-2010, 04:20 PM | #7 |
CCOTR Member
Drives: Victory Red 2010 2SS/RS A6 Join Date: Jun 2009
Get a Vector Motorsports tune or one from Jannety. They both have Transmission tunes and I can speak for the Vector, IT ROCKS! I had my AFM tuned out. Vector provides 2 levels of trans tune one more aggressive the the other!
For the A6's, a trans tune is a must !
Camaro Club Of The Rockies (CCOTR) Check us out on Facebook!
--------------------------- 2010 Camaro SS/RS Victory Red A6- Vararam Intake, Doug Thorley Tri Y LTs, Magnaflow X-pipe, Flowmaster Super 40's, VMS Tune, Razzi Ground Effects, Herritage Grill, RED headlight and fog light Halos, LED DRLs, Dash and extended Door ABL, engine, grill and rear defusser LED lighting ........ 12.59@112.21 (DA Corrected) |
05-21-2010, 08:19 PM | #8 |
Motor Head
This is exactly what I have done. D mode is pretty much what the factory gave us. S mode is where I did most of the adjustments.
05-24-2010, 11:37 AM | #9 |
Carguy
Drives: 57Chevy,67,80,2@10's camaro's,04SSR Join Date: Jan 2009
Had my A6 reprogrammed with tune and changed shift points on all settings..Dropped AFM. Speed limiter all that crap and man what a difference.
I have a friend who is going nuts over the AFM. He drove my car and went straight to the shop for a tune. Whole different car. I bought the auto for my wife but now I almost enjoy driving it as much as my LS3. Its fast and fun no more falling on its face when the AFM kicks in..Man that drove me nuts...I mean My wife nuts
2010 SS/RS LS3, 21" Rims, SLP lowering Kit & sway bars, TVS2300, Hennesy CAI, Kooks LT Headrers & Cats, Corsa Exhaust, RIP Shift ST shifter, SLP Hood & Spoiler, Slp Black out package - Grill SS & Rear SS Emblems, ADM Dual Fuel Pump , 3.6 upper Pulley, 10% overdriven Innovators West Crank Pulley& Pin Kit. .................................................. .............................. |
05-24-2010, 12:20 PM | #10 | |
I put the FU back in FUN
Drives: 1969 SS 396 , 2010 Camaro SS Join Date: Jun 2009
I dont know if you are willing to Drive to DFW but I had ADM tune my l99 and OMG I have 1 7/8 longtubes , Xpipe and Axlebacks ADM Cold Air Race Intake And a ADM Tune My car woke up 50X more than stock. off the line you gotta be gentle out of the hole otherwise you will smoke the tires About 60 mph its Climbs VERY QUICKLY to 90+ and I mean VERY QUICKLY Thanks to ADM and there Tune this baby is totally different animal. PM them on here or give them a call ADMperformance.com I Recommend Andy to anyone he knows his $hit . |
05-24-2010, 12:20 PM | #11 |
Drives: 2006 Dodge Charger / 2SS IOM Join Date: Dec 2008
i drove in the car with a guy that had a tune. there is a BIG difference and it will be even better with mods. i cant wait to get mine
05-24-2010, 03:02 PM | #12 | |
I'm not totally useless..
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
05-25-2010, 07:19 AM | #13 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2010
Jannety tunes are also awesome tunes! Any additional upgrade you add to the car, just email Ted and he will email you an updated tune! Not to mention this guy has been tuning cars for a Loooooooooooooong time! he knows his stuff! It is the reason I bought from him!
2010 Camaro 2SS/RS
Imperial Blue | Grey two-tone Interior | Silver racing stripes | Magnaflow Comp Cat-back | CAI intake | Elite Engineering Tunnel Brace | Richmond (Houston), TX |
05-25-2010, 11:28 AM | #14 |
These new A6's when tuned properly change the car and the way it drives full circle. You can actually enjoy the car for the reason's you purchased it.
Similar Threads | ||||
Any modded 5th gen SS's here that outrun a stock C6Z? | thebrander | 5th Gen Camaro SS LS LT General Discussions | 9 | 05-15-2010 04:23 PM |
Where can I guy get a good tune in the central FL area? | bumblebeecamaro | Tuning / Diagnostics -- engine and transmission | 4 | 02-04-2010 05:28 PM |
Undetectable Tunes - What You Should Know | kelley@vectormotorsports | V8 Bolt-Ons & Tunes | 159 | 09-18-2009 02:18 PM |
Can we spect a good increase in power with a tune and CAI? | alex33x | 5th Gen Camaro SS LS LT General Discussions | 5 | 04-09-2009 01:42 PM |
Edmunds.com review of Holden Commodore... good info. | LSxcellent | General Automotive + Other Cars Discussion | 6 | 07-23-2007 06:49 PM |
