Old 01-31-2011, 10:27 AM   #1
JM10
Se habla espaņol
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
ZR1 Clutch at the Track
Yesterday I went to a local track and Did a 2nd Gear burnout (I always do it in 1st). As soon as I launch the revs keep climbing in a crazy way, I tought that the tires were spinning. Half the track I let go because something was wrong.
At the end a lot of smoke was inside the car (Clutch)
I let the car rest, and make a 2nd run and got my best time 11.87
Do you think I broke the clutch?
What is the proper way to heat the tires, Im using NT05R with stock wheels..
JM
2010 VR 2SS/RS
BMR Suspension Parts
Hendrix HD Axles
DSS Aluminum Shaft
RPM Diff / 3.91 Gears
LPE ZR1 Clutch
Edelbrock E-Force SC / JRE Fuel Upgrade
Livernois 1C cam 570 rwhp/559 rwtq SAE
Best 1/4 time: 11.43
JM10 is offline   Reply With Quote
Old 01-31-2011, 10:31 AM   #2
boostedyards86
boostedyards86's Avatar
Drives: Cummins 3500
I always do a burnout in 2 gear... however seems you may have heated the clutch up way too much on the launch
85 Buick TType - 5.3l GT4202r 10.86 at 126
boostedyards86 is offline   Reply With Quote
Old 01-31-2011, 10:58 AM   #3
JM10
Se habla espaņol
JM10's Avatar
I guess...the launch was at almost 4K...
Did I shorten the life of the clutch?
2010 VR 2SS/RS
Hendrix HD Axles
DSS Aluminum Shaft
LPE ZR1 Clutch
Old 01-31-2011, 11:02 AM   #4
2010 2-Tone
Drives: 2010 RY 2SS with Custom Stripes
Is there any benefit to doing it in 2nd or is that only for supercharged cars?
2010 2-Tone is offline   Reply With Quote
Old 01-31-2011, 11:08 AM   #5
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
you should always do your burnout in 2nd gear... no matter what your setup is
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 01-31-2011, 11:48 AM   #6
acowherd
acowherd's Avatar
Drives: 2010 2ss/RS 4l80. 2009 2500 HD
The short answer......YES!!!!
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379
FNSS Racing!
acowherd is offline   Reply With Quote
Old 01-31-2011, 12:13 PM   #7
JM10
Se habla espaņol
JM10's Avatar
Sometimes you ask questions knowing the answer....:(
So what was the problem? the long burnout in 2nd gear (John Force style) or the launch at 4K?
JM
2010 VR 2SS/RS
Hendrix HD Axles
DSS Aluminum Shaft
LPE ZR1 Clutch
Old 01-31-2011, 12:20 PM   #8
acowherd
acowherd's Avatar
More than likely the 4k launch SLIPPING the clutch too much, and it over heated. Try and get out of the clutch sooner. Good thing is that the LS9 clutch is pretty resilient.
FNSS Racing!
Old 01-31-2011, 01:04 PM   #9
JM10
Se habla espaņol
JM10's Avatar
Now that you mention "slipping the clutch" I had a hard time turning the second set of lights...So I was at 4K slipping the clutch to move the car a little forward.
I was facing a turbo diesel truck with a Pro Stock style lights, thats why I wanted to keep the revs up....my bad...
NOW I KNOW that the problem wasnt the burnout or the launch... it was the time I spent trying to turn on the second set of lights at 4K
Thanks for your input.
JM
Old 01-31-2011, 03:10 PM   #10
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
If your sitting and holding the car at 4k and bump it up to get the light on... I dont think thats the problem because the clutch is not grabbing yet, once you take off and ride the clutch out that is causing all the heat. I think you must of been ridding the clutch to long out of the hole. Your clutch is going to be ok, just dont make a habbit out of it!
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 01-31-2011, 05:37 PM   #11
godfathercrc
godfathercrc's Avatar
Drives: 2010 Chevy Camaro SS
burnout
Install a linelock better burnout and easyer on your brakes
godfathercrc is offline   Reply With Quote
Old 02-02-2011, 12:52 PM   #12
Nmbr1gmfan
Drives: Fast
The tires probably never spun in the burnout, it was probably the clutch.
http://www.youtube.com/watch?v=fPvVm...&feature=share
New and improved non-violation sig vid!!
Nmbr1gmfan is offline   Reply With Quote
Old 02-08-2011, 04:03 PM   #13
nuptualnemesis
NuptualNemesis
nuptualnemesis's Avatar
Drives: Silver 1SS M6 - 480hp 11.57/120.79
Don't slip the clutch for a burn out. Always pop the clutch in second on the wet concrete. (this is the only time you actually pop the clutch - slip it to launch) If you smell it you slipped it too much. Be careful to fully release the clutch. Take your foot all the way off if you think it is slipping. I found my self applying a small amount of pressure getting ready to shift causing it to slip.
If you smell it let it cool down 30 minutes to an hour. Probably did not hurt in unless slipping through a couple of gears.
nuptualnemesis is offline   Reply With Quote
Old 02-08-2011, 06:44 PM   #14
Farks Supercars
Farks Supercars's Avatar
Drives: F1R 2010 Camaro
Your clutch will most likely be fine. Remember, the higher you rev the engine before you pop the clutch to do a burnout the smaller chance you have of slipping the clutch.
Farks Supercars is offline   Reply With Quote
Clutch Problem phenixdragon Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 20 08-22-2010 10:51 AM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 10:40 PM
SPEED INC TVS 2300 2010 CAMARO TRACK RESULTS!!! Bryan @ Speed Inc. Dragstrip and Launch Techniques Discussion 10 08-15-2009 12:28 AM
Chevrolet Corvette ZR1 (2008) andykhol23 General Automotive + Other Cars Discussion 3 05-21-2008 11:24 PM
Corvette ZR1 Testing at Nürburgring...Oh man. Urthman General Automotive + Other Cars Discussion 24 05-05-2008 08:46 PM
