07-16-2011, 09:54 PM | #1 |
Drives: black camaro, duramax, and cobalt Join Date: Mar 2010
Stock engine, broken axle?
I am not one to run my car hard at all but today I wanted to do a nice holeshot.. shut traction and stabilitrak off and dumped it at about 4k, lit them up real nice just like I wanted shifted into second then pop grind grind grind... Broke the pasenger side axle at wheel???.. car only has exhaust and intake, no tune. The car is lowered, would that throw of the axles and cause this? WTF? the car only has 780 miles on it.. dealer said no problem, we will tow it in and fix it
But what I dont like is the fact that it might happen again. I shouldnt have to upgrade axles on stock engine you can see where I shifted to second, it spun just a bit then broke. You can see the grease on the road on the pasenger side |
07-16-2011, 09:57 PM | #2 |
Guest
That's a pretty common problem with these cars. If your going to carry on like that you should get some Hendrick HP axles.
07-16-2011, 10:01 PM | #3 |
Drives: 99 Camaro SS, 79 z28, 70 GTX Join Date: Oct 2009
its not so much the hp as the traction and wheel hop that breaks things
07-16-2011, 10:07 PM | #4 |
Drives: cars Join Date: May 2011
Dumping the clutch and doing massive burnouts with a stock suspension will do that. And I'm pretty sure that falls under running the car hard.
You should consider trailing arms, toe rods, and subframe bushing inserts or replacements to prevent wheelhop. Then you won't break them again the next time you do a burnout. Wheelhop will break even upgraded axles and differentials. I just did the bushings and the other trailing arms and toe rods will happen in a month or two. I don't want to take it to the track until I do so I can ensure what happened to you doesn't happen to me. You have an awesome dealer for replacing axles next to big burnout tracks. |
07-16-2011, 10:08 PM | #5 | |
Drives: 2010 Camaro 2SS/RS RJT, 6speed Join Date: May 2011
Hop
Surprised with stock it got bad enough to break the axle but it sure can happen. Toe rods and trailing arms!!!!!! Need to do mine as well!! |
07-16-2011, 10:10 PM | #6 |
so what your saying is, Fix the wheel hop and get more hp for less traction? I like that idea LOL
07-16-2011, 10:21 PM | #7 |
07-16-2011, 11:09 PM | #8 |
Drives: A Gift From My Wife Join Date: Apr 2009
2012 Convert 2SS/RS SW/IO LS3 - Build #1081
07/21/2011 - (3800) Order produced and vehicle is being prepared for shipping. 08/09/2011 - (4200) Shipped (vehicle is shipped to the dealer or interim point of delivery). 08/16/2011 - (5000) Vehicle has been delivered to dealer. 08/19/2011 - In my possession. |
07-16-2011, 11:30 PM | #9 | |
Drives: 2010 Ford Raptor Join Date: Aug 2007
Since this is just a smokin-of-the-tires, next time in stead of a straight line, sway to one side or another or a slight "S" and wheel hop usually does not happen. Try all four and you will see that straight line is the only time your wheels will hop and snap shafts. Also there is to much stress in a straight line..... |
07-17-2011, 12:31 AM | #10 |
4K drop is a hell of a shock to the drivetrain. I am sure that did not help any either.
07-17-2011, 12:47 AM | #11 | |
Drives: 2011 Camaro 2SS Join Date: Jul 2011
07-17-2011, 06:31 AM | #12 |
"To Punish And Enslave"
Drives: B E RS GBA #72541 3564 CC 220 CI Join Date: May 2011
learned something new here
but on my car at like 200 a pop for each p zero tire im not doing burn outs soon ill be paying out my ass in tires and satan forbid i break something sure dealer may cover it but if not im screwed lol
C.A.M.A.R.O- Constantly Adding Modifications Addiction Relentless Obsession 90% canadian 10% mexican 100% american muscle :flag2: |
07-17-2011, 06:49 AM | #13 |
If i were you I wouldn't go posting the pic of your "Burnout" online.. The dealer is going to fix it but I mean.. This isn't a normal acceleration issue that caused your problem..
07-17-2011, 07:06 AM | #14 |
Drives: 1992 Chevy K5 Blazer Join Date: Apr 2011
Yep!!
Love beautiful photos? Please visit:
http://dougloganphotography.zenfolio.com |
Similar Threads | ||||
Pfadt Engine Mounts installed, first and second impressions... | robertway | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 6 | 03-03-2010 09:35 AM |
The BEST Break for a new car. "very long" | Darin Morgan | General Automotive + Other Cars Discussion | 346 | 02-04-2010 06:49 PM |
Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 01:00 PM |
