05-28-2012, 11:28 AM | #1 |
Drives: 2SS/RS Join Date: Jul 2009
6 bolt / Cylinder head guys, step in please.
So finally some progress is being made on my project untill last night. We have the engine on the stand and noticed that the stock casting exhaust manifolds will not clear the "6th" bolt or the extra bolts for the #7 and #8 cylinder. This is an issue because the IPS turbo kit was designed to re-use these manifolds for their strength and their heat retention. My first thought was to try and use a shorty header designed for the 5th gen but I am not sure if they will clear the extra bolts or if they are structurally strong enough to support the turbos? Obviously the best option is a custom turbo manifold but my last quote of $2,000 seems a bit rough. Any thoughts and suggtions are greatly appreciated.
Thanks, |
05-28-2012, 05:16 PM | #2 |
Drives: 2010 Camaro 2SS/RS Join Date: Sep 2009
I would call IPS as they did a RHS block with RHS 6 bolt heads and had to do a custom manifold for it in place of the stock one. If they kept the jig then they can make you one just like it.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock 2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo |
05-28-2012, 06:25 PM | #3 |
Drives: 2010 Camaro 2SS Join Date: May 2011
Hope you get it figured out. I have been following your build since CBI did the work to the car I bought!
Whipple,custom cam,CAI,Kooks,Pedders and PFADT 626RWHP 549TQ ..
05-28-2012, 06:41 PM | #4 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
I think Darth Emma has a real similar build. I think she had custom tubes made though.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
05-30-2012, 02:20 PM | #5 |
Drives: turbo Join Date: May 2011
Good luck on catching up with them ... they shut down for 2 weeks to catch up im having issues too with my heads and the car is at IPS
05-30-2012, 05:38 PM | #6 |
Ghostly Unknown
Drives: Silver Ice 2010 SS/RS A6 Join Date: Oct 2008
I knew this was gonna be an issue for future builds with the 6 bolt heads when retaining the factory manifolds on these turbo builds which is exactly what I did.All you gotta do is put a couple of bolts in there to hold it so it'll be properly aligned mark it with a sharpie,take it back off,take a diegrinder and take sum material out,I have the GMPP LSX heads and I had to take it all the way down till there was a hole in the manifold so it would clear,then I came in from the back/inside with sum mild steel and tig welded,smoothed it out turned out nice,I think I might have sum pics somewhere if I can find them,Any good fab shop should be able to do that for you for about $100.00 bucks
TS416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors, Lonnies Twin Pump Setup,Level 3 4L80E,DSS,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,Aeroforce Interceptor,AEM Truboost Controller,matte black CF5 Forgestars.700rwhp/712rwtrq
05-30-2012, 06:38 PM | #7 | |
05-30-2012, 06:53 PM | #8 |
Ghostly Unknown
Absolutely..
05-30-2012, 11:40 PM | #9 |
CBI had a few extra manifolds laying around so we tested a few ideas. First was heating up and bending but the bend was so severe the cast showed signs of fatigue, so next he cut a hole and welded a flat plate in its place but I didn't feel comfortable with that either for longevity sake. So the decision was made to create a custom set of tubular manifolds. I will keep the threads updated as progress continues. Thanks guys.
07-02-2020, 12:18 AM | #10 | |
Sure you will. |
07-05-2020, 12:28 AM | #11 | |
modify
07-06-2020, 03:46 PM | #12 |
Drives: it changes Join Date: Nov 2010
