06-07-2020, 04:02 PM | #1 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
winter project is done/time to tune
I got the fab work done and it's time to tune this baby.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
06-07-2020, 05:00 PM | #2 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
What you shooting for on the dyno?
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
06-07-2020, 05:08 PM | #3 |
Probally be happy when I'm in the 700whp range. When the weathers nice its a daily driver. I started on it in late Jan and got slowed down by the covid crap. I am going to be working on the tune as much as I can, but I have a dyno session set up for the 25th of this month, so we will see how it performs.
06-07-2020, 06:13 PM | #4 |
What size turbos?
06-07-2020, 06:49 PM | #5 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
Looks beautiful nice work!
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
06-07-2020, 09:36 PM | #6 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Ditto!
06-08-2020, 06:41 AM | #7 |
Turbo is a PT7675 (.81 AR)
I built the manifolds and all of the pipes. (Hot side, Cold side and exhaust)(I have pics of everything if anyone wants to see them) Its all purge welded stainless steel. (Pressure tested to 40psi) I plan on running 12psi That picture is a little old, I have changed the wrap and added some heat shields since.
06-08-2020, 10:47 AM | #8 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Are you tuning it yourself? I'm thinking about giving it a try on my new setup, but dont have the time right now.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
06-08-2020, 11:23 AM | #9 |
Yes, most of it on the street and then finish up on the dyno for the wot pulls. Then maybe a tweak here or there afterwards.
06-09-2020, 08:50 PM | #10 |
Looks Great !!
Who’s coil relocation brackets do you have ? |
06-09-2020, 09:02 PM | #11 |
Drives: 2011 Camaro SS Join Date: Jul 2017
Awesome job. What size DP and does it connect to your exhaust?
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
06-10-2020, 08:45 AM | #12 | ||
Down pipe Mid pipe (The bend is to clear the cross over pipe) Tail pipe
06-10-2020, 09:58 AM | #13 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Nice!
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
06-10-2020, 10:05 AM | #14 |
Took a crazy amount of time fitting things up so that I didn't have to really move or lose anything.
The intercooler pipes were a complete nightmare. But they fit perfectly LoL
