04-18-2021, 11:09 AM | #1 |
Drives: 2013 2SS Join Date: Mar 2014
Fuel and FI
What horsepower level will the stock injectors and pump reliably support?
04-18-2021, 12:39 PM | #2 |
Drives: 2010 ss Join Date: Oct 2015
correct me if im wrong guys,but i think most do full mods and cam on stock fuel systems.so about 485 rwhp
04-18-2021, 06:22 PM | #3 |
Drives: 15 Camaro SS Join Date: Oct 2018
If staying all motor it would take a bit. Forced induction and e85 take alot of fuel. Lots of variable here
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
04-18-2021, 06:48 PM | #4 |
I am limited to 90 octane pump gas (but I guess I could do octane boosters but not sure I want to mess with that everytime I fill up). I will either get a PD blower or centri blower.
04-18-2021, 07:08 PM | #5 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Methanol is a good option.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
04-18-2021, 07:09 PM | #6 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
My ZL1 pump topped out around 580hp. With the BAP, it hit 712 with room to spare. I would not try FI on a stock SS fuel pump.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
04-19-2021, 09:47 AM | #7 |
Drives: 2012 Camaro SS Join Date: Jun 2019
The Whipple kit I bought came with a BAP for the stock SS pump, and I ran that for 2 years with no issues. I'm assuming Whipple did enough testing to ensure the stock SS pump and BAP will handle a Whipple with the 4" pulley. It was a conservative tune though.
If you start dropping pulley sizes, adding a cam, 3" exhaust, tuning, etc etc you will need a bigger fuel system. If you are just doing an FI kit, you can get away with an SS pump and a BAP.
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
04-20-2021, 05:42 AM | #8 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
If you're running boost, the engine will be blowing against the injectors, and the pump will struggle to keep up fuel pressure. I personally would not even try using a stock fuel pump or stock injectors with Forced Induction. You would see them max out sooner than NA. FI aint cheap. You need at least a ZL1 pump (and fpcm tune) and some injectors.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
04-20-2021, 10:18 PM | #9 |
Anywhere from 550-580 depending on the car and the ability of the tuner. I ran just under 600 for years on a bone stock fuel pump without a problem.
That is cutting it very close but it worked. |
04-21-2021, 08:48 PM | #10 | |
I think I'd be quite happy at "only" 575 hp. |
04-22-2021, 09:37 AM | #11 |
For the record, I upgraded to a ZL1 pump in order to hit the 600rwhp I'm at now. When I went from stock to the Whipple kit, it was fine on the SS pump and BAP, which is what Whipple recommended.
