04-06-2022, 03:00 PM | #1 |
Drives: 2012 SS Join Date: Dec 2021
hoping for some suggestions about bluetooth
this is the first GM I have dealt with syncing my iphone to the radio. phone works fine. settings says it's connected in bluetooth. however, it only sporadically will play my music. no idea how to make it play. I have used a USB cable, no cable and every once in awhile it plays. otherwise....no. any ideas would be appreciated.
2012 Camaro SS
04-06-2022, 03:28 PM | #2 |
Drives: 2011 Camaro SS Join Date: Dec 2016
04-06-2022, 03:54 PM | #3 |
Drives: 1973 z28 Rs , 2012 SS/Rs Blk/Blk M6 Join Date: Oct 2009
On my 12 if it connects you need to change to radio then back to start music. Sounds much better through the cable in console and the iPod selection on radio.
04-07-2022, 03:08 PM | #4 |
Thank you both very much!!!!! I am going to try it. I really appreciate it!!!!!!
2012 Camaro SS
04-08-2022, 06:51 AM | #5 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
That video above helped me set mine up.
Just make sure that on your phones bluetooth you are connected to both "my vehicle" and "GmusicConnect". Your radio screen should pull up your phone name on the display. Once it does, you are connected to bluetooth calling and music streaming. If I am connected to both I just go into my phone, open spotify and hit Play on my music! Would be happy to help with more information if you need it.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
04-08-2022, 08:32 AM | #6 |
Thank you!!!!!
2012 Camaro SS
04-08-2022, 09:06 AM | #7 |
after a glitch or too, I got it. Thanks much everyone. finally!!!!! I can listen to my music.
2012 Camaro SS
