12-05-2013, 09:47 AM | #1 |
Philippians 4:13
Drives: SLP Supercharged LS3 Join Date: Aug 2009
Those who have converted from single to dual tips exhaust… step inside
I like many of you are interested in switching over to the dual tip look on my Camaro. I am looking at going with the 1LE diffuser. My question is this… has anyone done this dual tip swap that is currently running an SLP axle back? I have the LMII and the stock single tip will unbolt easy enough, but by the looks of it if I just bolt on a dual tip it will not clear the 1LE diffuser outlet. If you have done this was there a lot of fabrication that had to go into the exhaust or did it need just minor adjustment?
This is one of the sets I was looking at to swap out my tips with: http://tips.byethost4.com/dualpair.html Thanks
12-05-2013, 01:37 PM | #2 |
come find out;)
Drives: stockish 2012 camaro ss Join Date: Oct 2012
They will have to cut and reweld to adjust the position of your tips as they will not line up perfectly.
12-05-2013, 03:27 PM | #3 |
Any exhaust shop should be able to handle it pretty easily. I suggest visiting a few shops and getting a couple quotes.
Best regards, Tyler 888-308-6007 |
