12-12-2010, 01:13 AM | #1 |
Storage flat spots?
well my Camaro is in the garage like everyone elses for the snow and i was having a conversation with my cousin (mechanical engineer) well he says i'm stupid because i don't have it jacked up and ill get flat spots? is that true or its not that serious because i'm going to drive in when the snows gone.....
12-12-2010, 06:26 AM | #2 |
having FUN now 13.66@101
Do not jack it up and hang the suspension. Bad for the shocks and springs. Today's tires will flat spot slightly but not like the tires of years past. Best thing would be to over inflate the tires to around 45 PSI. In the spring just remember to reset the PSI and drive it. The flat spot will work themselves out shortly. If you want further info on this subject do a search on the forum, been discussed heavily. Lastly you can park it on some flat spot preventer's. These tend to help stop the flat spots from occurring. Again while searching for info you will see what others have done for this item.
Good Luck
12-12-2010, 08:42 AM | #3 |
Drives: 2010 2SS Join Date: Apr 2010
My car sat for 2 or 3 of months at a time last winter. No problems.
12-12-2010, 10:21 AM | #4 |
Drives: IBM 2010 Camaro LS Join Date: Jun 2010
I would go and move the car forward a few feet after a couple weeks, then back in another couple weeks, which prevented getting any flat spots. Of course, I don't know how convenient this would be for you, but I have mine stored only about five minutes from my house.
12-12-2010, 11:32 AM | #5 | |
12-12-2010, 03:34 PM | #6 | |
Drives: '11 2SS/RS RJT M6 Join Date: Oct 2010
12-12-2010, 07:57 PM | #7 |
"Camaro Joe"
there are rubber mats designed to keep you from flatspotting your tires, check out midamerica they have them off the top of my head
01-27-2011, 10:08 PM | #8 |
Drives: 13 Summit white ZL1 Join Date: Feb 2010
steel belted tires will have a flat spot after time, but as soon as you take it back out and run it a few miles it goes away
01-27-2011, 10:18 PM | #9 |
my Camaro sat all last Winter and no flat spots and the battery did not die either.
Similar Threads | ||||
Avoiding Flat spots on your tires during winter storage?? | Camaro Freak | Wheels and Tires Talk Sponsored by The Tire Rack | 20 | 10-24-2010 01:05 PM |
tire stands to prevent flat spots | Darth_Emma | Wheels and Tires Talk Sponsored by The Tire Rack | 11 | 06-28-2010 08:03 AM |
Is there a way to remove flat spots? | BunkG | 4th Generation Camaros | 7 | 04-09-2010 07:39 AM |
Tires... flat spots | jrcase | 5th Gen Camaro SS LS LT General Discussions | 27 | 03-02-2010 09:03 PM |
