04-16-2011, 05:33 PM | #1 |
Drives: anything Join Date: Aug 2010
Clutch pedal not returning problem at Camaro5 - solved
Here are some pictures of installing our clutch pedal return spring kit in a customer vehicle (600LPE) at Camaro5. During the first day he had problems with the clutch pedal not returning after high rpm shifts. We had one of our clutch pedal return spring kits on our 800TT Camaro display vehicle so we removed it from that vehicle and installed it on his car.
Problem solved. The clutch pedal return kit is available in two versions right now - one for the 5th Gen Camaro and one for the C5 and C6 Corvettes. BTW - this car has a roll cage with a fixed door bar so that made the installation a bit more difficult. The quick-disconnect steering wheel didn't help the install but it made taking the pictures easier. |
04-16-2011, 06:16 PM | #2 |
Drives: '10 2SS/RS Cyber Grey Camaro (sold) Join Date: Nov 2010
how much more leg do you have to give it with the added tension of that spring? would a clutch upgrade say maybe a new 2 disc set up help?
04-17-2011, 12:34 AM | #3 |
new comer
Drives: 2011 camaro v6 1lt rs Join Date: Apr 2011
awsome FIX......the first day i got my new maro, i had this problem but i think mine was more of a hydralic prob....but i may try this, is this feel good for performance driving?
Real cars dont power the front wheels, They lift them.
04-17-2011, 07:04 AM | #4 |
Drives: 04 sentra, 2ss Join Date: Apr 2009
Sweet can you pm. Me a price
04-17-2011, 08:21 AM | #5 |
220/221 whatever it takes
Drives: See sig.... Join Date: Jun 2010
Brent
2022 BMW X5 M50i 2022 Ram TRX 2021 GT500 CFHP 2016 Challenger Hellcat A8 1058whp/898wtq 1970 Chevelle SS396 4spd |
04-21-2011, 11:02 AM | #6 |
can you post the instructions on the tread. never got them and the fax the pictures are to dark the only problem im having is finding the hole behind the obd?
thanks
04-21-2011, 11:41 AM | #7 |
I did that on my Camaro a while back and it Works Great !! Since then, I have replaced my clutch with the LPE ZR-1 Clutch.. No more issues !!
04-21-2011, 11:45 AM | #8 |
Drives: 89 IROC 350 Join Date: Mar 2009
Seems like a way to mask a problem that shouldn't be there to begin with.
04-21-2011, 12:11 PM | #9 |
Drives: 2010 IOM 2SS/RS Join Date: Oct 2008
I'd like to know how this changes the pedal effort
04-21-2011, 12:22 PM | #10 |
camaro21 do you know where it connects to the body??
jrhaus76 i believe your right this is just a band aid to a problem we shouldn't be having. outatime ill get back to you on how the clutch pedal feels after i install.
04-26-2011, 08:58 AM | #11 |
Drives: 2010 Join Date: Jul 2009
It doesn't add too much more effort to the clutch pedal. I could drive with this fix all day long in traffic.
It saved my weekend... and now I don't have to worry about the clutch pedal sticking to the floor or 1/2 way down anymore. Once my car is back from the Fest, I will try to take a picture of what the spring connects to. |
04-27-2011, 03:59 PM | #12 |
i installed this mod also. very simple to install. however i found that the spring added more tension than i would like hard to play around w. the clutch esp. in traffic. i just went to home depot and bought different spring tensions and i installed the spring that suited me best. its hard to go back to the stock feeling after this install. this mod helps with the stuck clutch pedal.
04-27-2011, 05:31 PM | #13 | |
Drives: 2011 Camaro SS2/LS3 Join Date: Feb 2011
Isn't the real solution to upgrade the fluid and separate it out into its own reservoir?
2011 Chevrolet Camaro SS2/LS3 - Pretty much bone stock (SLP SkipShift Eliminator, GTO clutch fluid reservoir mod) - 13.025 @ 110.492 MPH (12s?? )
1998 Pontiac Grand Prix GTP (retired) - Cam, exhaust, CAI, 12 PSI, tune - 13.465 @ 101.04 MPH |
04-29-2011, 03:00 PM | #14 | ||
High on "The Camaro Life"
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam Join Date: May 2009
The spring stops the problem by allowing the clutch to release even with hot fluid.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
Similar Threads | ||||
We solved the 1 wheel burnout problem | JANNETTYRACING | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 202 | 05-01-2017 02:49 PM |
Clutch fluid contamination problems on Vette fixed for Camaro??? | LDGn63 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 11 | 05-28-2012 09:17 PM |
Clutch pedal squeaky noise | buddylok | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 01-03-2012 05:34 PM |
Question for seasoned stick shift drivers | tommygun6644 | Dragstrip and Launch Techniques Discussion | 69 | 10-11-2010 10:42 PM |
Does anyone else have a Gas Pedal Problem? | DVG's 2010 SS2 | 5th Gen Camaro SS LS LT General Discussions | 13 | 10-02-2009 10:42 AM |
