01-07-2015, 04:10 PM | #1 |
Drives: 2010 2SS/RS Camaro Join Date: Aug 2014
Removing dash on a 2010 Camaro Question?
I am designing a gauge panel for my 2010 SS Camaro that will hold 3 or 4, 2 1/16 or 2 5/8 dia. gauges & will be located where the factory center HVAC vent is located.
To gain access to the back side of the 2010 & 2011 Camaro center HVAC vent to remove it, you must remove the entire dash. My question is, has anyone on the forum removed the entire dash from their 2010 or 2011 camaro that could give me some information regarding the correct way of doing it. Any & all information would be appreciated. All The Best, Orange 2010 Camaro |
01-07-2015, 05:05 PM | #2 |
Drives: 2011 Camaro LS Join Date: Jan 2012
Here are the instructions on how to retrofit Heads up display into a camaro. The process requires removing the dash, so maybe this will help you. http://www.gen5diy.com/image/data/PDFs/HUD_Install.pdf
01-08-2015, 12:58 PM | #3 | |
Thank you SO MUCH for the dash removal link. That is what this forum is all about! All The Best, Orange 2010 Camaro |
01-08-2015, 01:15 PM | #4 | |
No problem man, did you get to read through the instructions? Did you find them helpful? Sent from my iPhone using Tapatalk
01-09-2015, 02:08 PM | #5 | |
Yes, I did read through all the instructions. Looks like about a 3 to 4 hr. job to remove the dash, & I will soon find out. Thanks Again, Orange 2010 Camaro |
01-09-2015, 02:47 PM | #6 | |
Cool. Good luck! Sent from my iPhone using Tapatalk
