JUICEDMOTORSPORTS
Old 12-20-2015, 08:04 PM   #1
Bigtime53
Bigtime53's Avatar
Drives: 2015 ZL1
D3 COOLANT RESERVOIR INSTALL
I bought a D3 reservoir from a fellow member here and I am ready to get it installed. I set the reservoir where it needs to go and see where to bolt it on. What I need to know is which hose goes to the reservoir? I have looked at them but I sure do not want to cut the wrong one. I did a search here and could not find anything about how to do this and tried the rotofab reservoir install and no luck there either. Those of you who have installed one guide me in the right direction.Thanks
Bigtime53 is offline   Reply With Quote
Old 12-20-2015, 08:39 PM   #2
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
I don't know what D3 recommends but the rotofab puts the reservoir right after the supercharger.... then the reservoir feeds the pump. After I melted down one reservoir with superheated steam coming out of the supercharger, I put my reservoir in line between the heat exchanger in the grill and the cold side of the supercharger. It works a little better that way. Really you could put it anywhere in line as long as your fluid never gets crazy hot. If you ever plan on using ice in the reservoir it really needs to be right before the supercharger inlet to be the most effective.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 12-20-2015, 08:52 PM   #3
Bigtime53
Bigtime53's Avatar
Drives: 2015 ZL1
Hey Jess how are you? Have not talked to you in a while. Your car going again and if so how is it? I think I read here you bought a vette to. Did you get a ZO6? Anyway, thanks for the info.
Old 12-20-2015, 08:58 PM   #4
CanadianZL1#992
ANGRY Z
CanadianZL1#992's Avatar
Drives: 2015 Camaro ZL1
There's a couple of pictures in a D3 tank thread in the ZL1 drivetrain section that show which hose was cut for the tank. Looks like the drivers side
2015 ZL1 A6 396 stroker RWHP- depends on nitrous
CanadianZL1#992 is offline   Reply With Quote
Old 12-20-2015, 09:06 PM   #5
m1key1111
Drives: 2012 ZL1
Driver side line to the top of the tank and the bottom line goes to the pump directly under it.
m1key1111 is offline   Reply With Quote
Old 12-20-2015, 09:23 PM   #6
Bigtime53
Bigtime53's Avatar
Drives: 2015 ZL1
Thanks mikey1111 that is exactly what I was hoping for. Your the man!
Old 12-20-2015, 09:51 PM   #7
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
About to do this install myself very soon.
Mods:
Old 12-20-2015, 10:45 PM   #8
hawk02
Coupe Newbie
hawk02's Avatar
Drives: 2017 Mosaic Black Metallic ZL1
Hey m1key1111, The inlet elbow on your Roto Fab intake needs to be flipped around. The fitting for the breather canister is supposed to be on the underside of the elbow.
hawk02 is offline   Reply With Quote
Old 12-21-2015, 05:51 AM   #9
Bigtime53
Bigtime53's Avatar
Drives: 2015 ZL1
I am going to have to look at mine when I get to the shop this morning. I may have installed mine the same way mikey did. [rotofab]
Old 12-21-2015, 12:10 PM   #10
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Originally Posted by hawk02 View Post
Hey m1key1111, The inlet elbow on your Roto Fab intake needs to flipped around. The fitting for breather canister is supposed to be on the underside of the elbow.
Good eye!
Mods:
Old 12-21-2015, 01:39 PM   #11
m1key1111
Drives: 2012 ZL1
Great catch, thanks!
Old 01-12-2018, 12:29 PM   #12
n0speedlimit
Drives: 2014 ZL1
do the fittings just screw on the d3 reservoir or will you need to apply some Teflon tape?
n0speedlimit is offline   Reply With Quote
Old 01-12-2018, 01:01 PM   #13
JB'sZL1
Drives: 2013 ZL1
No tape is necessary.
JB'sZL1 is offline   Reply With Quote
Old 01-12-2018, 01:43 PM   #14
Hellfighter
Hellfighter's Avatar
Drives: 2013 Black ZL1
Cant wait to get mine on.
Hellfighter is offline   Reply With Quote
