Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Members Area > Ask the Camaro Team
Old 09-25-2017, 03:51 PM   #1
wyd_trkr
wyd_trkr's Avatar
Drives: 2016 Camaro 2LT/RS A8
Question HVAC Moisture On Windshield On Going Problem?
Al, would you please share with us Gen6 Camaro Owners when Chevrolet will be issuing a Bonafide Fix Repair for this Very Dangerous Ongoing Problem with the AC Running in Higher Humidity areas of the US and with the AC blowing up through the Defroster Vent into the top of the dash, the Moisture is taking over the entire windshield and causing "0" Visibility Problems for us to see out through the windshield. We would appreciate any and all help you could share on this Very Important Subject. The current Technical Service Bulletin is totally useless and does not fix the problem, as several Gen6 Owners have wasted their time with taking their vehicle into their local Chevrolet Service Department for the fix and to no avail, it has proven unsuccessful. This is a shame for the Gen6 Owners to have to pay a Premium for our Gen6 Camaro's and have to be "Plagued" with this ongoing problem that GM has not fixed correctly for the past 3 models years (2016-2018) to date. Thank you for your assistance!
Regards, wyd_trkr
Bose Premium System
My Link Navigation
Onstar & Bluetooth Built-In
K&N Panel Filter
Lumar/Pro WindowTint
Mailto: wyd_trkr@bellsouth.net
wyd_trkr is offline   Reply With Quote
Old 09-28-2017, 06:43 PM   #2
wyd_trkr
wyd_trkr's Avatar
Question
I sure wish someone with GM would step in and let us all know when to expect a Fix for this ongoing problem with our Gen6 2016-2018 Camaro's!
Regards, wyd_trkr
Bose Premium System
My Link Navigation
K&N Panel Filter
Old 09-28-2017, 07:04 PM   #3
wyd_trkr
wyd_trkr's Avatar
For those following this thread, please read the post on Facebook Camaro 6th Generation:
https://www.facebook.com/groups/perm...comment_follow
Regards, wyd_trkr
Bose Premium System
My Link Navigation
K&N Panel Filter
Old 11-14-2017, 08:33 PM   #4
camaro5's Avatar
Drives: X-15 Velocipede
Leaking AC Mode Doors
The hvac case was inadequately designed so that the mode door could not contain the Blower cfm's at high fan speed.
This causes a fluttering mode door and the obnoxious sound that goes with it.
The solution was to ADD little foam blocks to hold the mode door open further than it's normal leak rate, so it wouldn't make the flutter sound at high fan speed.
Then, more complaints about air on windshield.
Ineffective TSB was released to remove added foam blocks, and reprogram BCM to lower fan speed cfm for high speed setting.
The mode doors still leak.
Door needs more foam weatherstripping. Might be able to get the actuator to pull it tighter.
Poor visibility through the windshield is not only maddening, it is an outright safety hazard.
I'm going to check this BEFORE taking delivery, and will NOT buy ANY car fogging (inside) and causing blinding condensation (outside) on its windshield.
Put a little more foam on the MODE door.
v
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 11-19-2017, 07:50 AM   #5
VQ35DE
Drives: 2013 / 2SS / RS / L99
v
So you are saying that they (GM /or supplier) have NOT applied this fix to current new 2018 production yet ?
VQ35DE is offline   Reply With Quote
Old 11-21-2017, 09:02 PM   #6
Commando16SS
Drives: n/a
Cliffs for those without FB?
Commando16SS is offline   Reply With Quote
