12-29-2013, 03:05 PM | #1 |
Untamed Performance EPT
Drives: 2011 2SS Join Date: Aug 2012
Slight hesitation
I know this may be primarily tune related, but Rhino is in the process of squaring this away .
The motor has slight hesitation as I smash the gas pedal. Its very appearant in 1st gear just after starting off from a stop. Its more dependant upon how hard I press the gas pedal. Idle-1800 rpm. Also in conjunction with a funny surge. Using stock plugs at the moment. Verified gaps and wires are good and installed properly. Check all the connectors for security and installation for the coil packs ect. I'm looking for probable mechanical things to look at. I know Rhino will finish the datalogging process after the holidays!
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK 9in. diff with 4.11's, DSS Axles, and Alum Shaft Hurst Short-Shifter; Ideal Garage Master Cylinder H-E Street Slayer Twin Billet Clutch BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings. Strange Rear Coilovers and mounts Tuned by Rhino79 |
01-02-2014, 08:37 PM | #2 |
bump
Night Fury Cam
01-02-2014, 09:04 PM | #3 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
If Rhino is looking at it, you might as well wait till he gets back with you. Anything anyone else suggests, without looking at the tune, is going to be pure speculation.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
01-02-2014, 09:19 PM | #4 |
On my '11 I had a weak MAF. I had a similar symptom youre describing
01-03-2014, 11:08 PM | #5 |
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60' Join Date: Jul 2009
We recommend the ngk 4177 plugs with a cam install.
let us know if we can help you! Nick |
01-04-2014, 09:51 AM | #6 | ||
I'm thinking he's on vacation still, so I'm waiting to hear back.
Night Fury Cam
01-04-2014, 11:29 AM | #7 |
Ill try and look at your file today man, holidays have been hectic.....lol.
01-04-2014, 01:00 PM | #8 |
Thanks buddy, i understand hah. Ill get the datalogs sent up next weekend. Broke my spider gears this weekend in my stock diff richmond 4.11s. Guess im tossing in the 9inch before FI afterall.
Night Fury Cam
01-04-2014, 10:44 PM | #9 |
Drives: 2011 LS3 Join Date: Jan 2012
You broke them yesterday at t&t night?
Stainless Works Headers Vmax TB SLP loudmouth 2 Nightfury Cam Mike Norris CC Tuned by Southwest Speed |
Thread Tools | |
