Old 02-16-2015, 12:38 PM   #1
VTXrider
VTXrider's Avatar
Drives: 2010 RY 2SS/RS
How to replace lumbar spring?
What is the best way to replace the lumbar springs in the from seats? My driver side broke, I got the new spring but am having trouble with changing it. I tried to go in through the back of the seat but can not get the top connection. It seems like you have to go in the front of the seat. In order to do this it seems that the cover is strapped in the bottom and you have to take the seat out to access this. Am I right?
What is the best way to replace the spring, can it be done with the seat in the car?
VTXrider is offline   Reply With Quote
Old 02-16-2015, 12:59 PM   #2
Hetfield03
Hetfield03's Avatar
Drives: 2010 2LT/RS Black/IOM
I wouldn't even know that its broken I don't think.
Hetfield03 is offline   Reply With Quote
Old 02-16-2015, 10:06 PM   #3
VTXrider
VTXrider's Avatar
You'd notice the difference pretty quick but first you hear it pop if it breaks.
Old 02-24-2015, 04:11 PM   #4
VTXrider
VTXrider's Avatar
Bump
Old 02-26-2015, 11:18 AM   #5
Denis
Denis's Avatar
Drives: 2010 SS
I think I heard mine pop...seat feels different. id like to fix it if theres a somewhat easy way to do it.
Old 02-27-2015, 03:17 PM   #6
VTXrider
VTXrider's Avatar
Yes, that's exactly it. The part cost me about $16 but I just can't figure out how to install without taking out the seat which I would like to avoid.
Old 03-15-2015, 04:29 PM   #7
jnikkila
jnikkila's Avatar
Drives: LS/LLT
This happened to me as well. I took it to the dealer and they fixed it under warranty. I was told they had to take material off of the seat and weld a new lumbar support into the seat frame...since then its been really stiff. I'll never buy a car without adjustable lumbar again.
jnikkila is offline   Reply With Quote
Old 09-19-2016, 07:30 PM   #8
bobcat1506
Drives: Drive'm
bump, who knows how to replace this part?
bobcat1506 is offline   Reply With Quote
Old 09-28-2016, 02:42 PM   #9
jer
jer's Avatar
Drives: 2012 Camaro 1LT RS
I had to do this today. I have a new upper and lower seat cover, had to replace the lumbar support as well as the foam back pad. Attached is the old and the new lumbar support. I had to remove the seat from the car, then remove the seat cover and disconnect the airbag from the seat. Remove the foam back pad and it's easy to take out the old lumbar support, a little more difficult to attach the new one. I used some needle nose pliers to get it all installed.
jer is offline   Reply With Quote
Old 11-20-2016, 01:49 PM   #10
VTXrider
VTXrider's Avatar
Thanks for the pics Jer. Question, how do you get the seat leather cover to go off over the part where you insert the headrest?
Old 10-08-2017, 02:12 PM   #11
kennyo
kennyo's Avatar
Drives: 2017 2SS Hyper Blue
Just did that a few days ago-you actually just pull the leather out from under it by hand
Mods-Corsa Extreme Axleback
kennyo is offline   Reply With Quote
Old 08-30-2019, 10:34 PM   #12
alini
alini's Avatar
Drives: 2016 Camaro Hyper Blue 2SS
Where did you find the parts from? I need to find a source for my 2016
** The above post is by someone who is not an expert **
2005 Pt Cruiser panel Conversion
2016 2SS Camaro Hyper Blue white interior
1937 Chevy truck. Full custom. Build in work
https://www.teamalini.com
alini is offline   Reply With Quote
Old 11-13-2019, 02:22 PM   #13
VTXrider
VTXrider's Avatar
Sorry for a late response, I've been on other forums a lot instead of here.
Best place I've found for GM parts is gmpartsdirect.com
