06-16-2016, 03:41 PM | #1 |
New alternator and recharged the battery????
I have a 2012 V6 camaro. I was driving home when the dash read battery saver mode. Eventually things shut off and the car died. So naturally the way things happened told me it was the alternator. I got a new one, charged the battery and now, the battery light is still on and I have no power steering. Help please.........
06-16-2016, 04:28 PM | #2 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Check all your connections, including grounding wires.
More to come. |
06-17-2016, 07:06 AM | #3 |
I have been working on cars for as long as I can remember. I've also been on a few forums and have seen some pretty dumb things. I am embarrassed to say, I didn't put the belt back on.
06-17-2016, 10:40 AM | #4 |
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300 Join Date: Nov 2011
Surely you do not mean alternator belt..
06-17-2016, 10:58 AM | #5 |
SomeguyK
More to come. |
06-17-2016, 03:00 PM | #6 |
Ed
Drives: 2015 camaro 1le 2ss Join Date: Apr 2016
What is your voltage reading while running? How much amperage is the new alternator producing? Did you check voltage at alternator plug? Lots of things to check before changing parts..
06-17-2016, 04:24 PM | #7 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
I hope this isn't the case.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
06-17-2016, 11:44 PM | #8 |
Drives: 2011 2SS Join Date: Aug 2014
Read his last post, 0 volts and zero amps. Sounds like it was just a missing alt belt. Woopsie!
Thread Tools | |
