Old 05-10-2014, 02:18 AM   #1
Rad_dsm
Rad_dsm's Avatar
Drives: 2011 synergy 2ss
Diff rebuild.
Hello.
I have a 2011 ss m6. I was wondering if anybody sells a kit to replace the clutch packs in the diff, thanks.
Rad_dsm is offline   Reply With Quote
Old 05-10-2014, 03:09 AM   #2
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Jannetty is the only one I know that works with the clutch packs. Most people either buy his upgrade or just go to a TruTrac.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 05-10-2014, 11:55 AM   #3
forklord
forklord's Avatar
Drives: 2010 2SS
go eaton trutrac (~600$) with lingenfelter or similar rear end rebuild kit (~200$) and youll be extremely happy. this is my next mod.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 05-11-2014, 11:19 PM   #4
Rad_dsm
Rad_dsm's Avatar
We'll I can't do a tru trac bc my autocross class doesn't allow replacement diff, just rebuild stock.
Old 05-12-2014, 08:50 AM   #5
BigRed
BigRed's Avatar
Drives: SS RS SIM
the tru trac goes inside your stock differential housing, they would never know.
BigRed is offline   Reply With Quote
