06-01-2011, 09:03 AM | #1 |
"First There"
Drives: 2010 camaro 2ss Join Date: Feb 2011
TSB revision on lifters.....pass along to dealerships!!!!!!
So in my recent i post i shared with you about my AFM parts going bad on me twice with in a short time period. long story short my cam had gone bad. Gm is going to make a revision to the lifters tsb to not only replace just the lifters but the lifter trays, cam, cam phaser, pretty much every thing that deals with AFM.... One of the lifters that they replaced turned sideways, which isnt suppose to happen and then just started beating up and down on my cam like a hammer because of the wear and tear on lifter trays(they are plastic?!!!!). My mech showed me the difference and it was pretty easy to tell how that happened.
So if you are going to the dealer for the tsb and lifters tell them to call tech assistance so that can also order the other parts that need to be replaced |
06-12-2011, 11:50 PM | #2 | |
Drives: 2011 Dodge 3500 dually Mega Cab Join Date: Jul 2009
06-13-2011, 05:20 AM | #3 |
Drives: 2011 Camaro SS Convertible! Join Date: Jun 2011
AFM is ruining the Camaro experience!
Yes - please let us know if any TSBs regarding the AFM are available. |
06-16-2011, 05:00 PM | #4 |
Drives: Black 2SS Join Date: Nov 2009
06-20-2011, 01:51 PM | #5 |
"First There"
thats a good question as far as i know it hasnt def talk to your dealers if you bring it in for this kind of work though
06-20-2011, 01:58 PM | #6 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
The tray is the only thing that holds the roller lifters in the correct position and (their plastic) and deformation will cause just such a failure. Glad you got it fixed!!!
06-20-2011, 02:03 PM | #7 |
Dear GM:
You have been building indestructable Small Block V8 engines since 1955. Please go back and look at those engines and LEARN SOMETHING. I am getting really tired of seeing a V8 issue on these forums EVERY SINGLE DAY - most of which were catastrophic. Thank you, Future L99 owner.
Cars and women are both going to give you problems...but you can pay somebody else to fix your car!
06-20-2011, 04:11 PM | #8 | |
"First There"
Its back together,having issues with compression in 3! cylinders, gm now wants us to remove engine and tear down to determine whether to replace or repair compression issues. So enjoy the hot rod aka HHR and i will let you know. FML! i dont know whether to cry or laugh at this point!!!!!! |
06-20-2011, 05:49 PM | #9 |
It will turn out good in the end. The loaner is real decent and the dealer seems to be one of the good ones.
06-26-2011, 06:27 PM | #10 |
Drives: 2010 2ss/rs IBM A6 Join Date: Nov 2010
I have already had my lifters replaced. Any suggestions on what I should do to get the other parts replaced?
Similar Threads | ||||
TSB Lifters Vin Range | aroar02 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 26 | 11-03-2014 12:33 PM |
Dealerships and TSB | RWR | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 0 | 09-21-2010 06:41 PM |
GM Dealerships Closings. Chevy & Cadillac still not mentioned | Richochet83 | General Automotive + Other Cars Discussion | 17 | 05-16-2009 11:57 AM |
Why you can't buy a new car directly from the manufacturer | scotchsride09 | Off-topic Discussions | 13 | 02-14-2009 05:15 PM |
