Old 06-05-2016, 10:39 AM   #1
Xndless
Drives: 2013 2SS/RS
Can't get my tires to break?
Yesterday I took my car out and it wasn't running as well as it usually does. I couldn't get my tires to break loose at all, and normally my tires can't stay planted.
They are pretty bald, but the road was extremely hot from the sun. Usually I can put it in 1st gear and floor it and the tires will spin, but all that was happening was my car was bogging down until it hit higher rpm.
A couple hours later my car felt a bit better, but it still wouldn't break the tires.
It's a 2013 2ss/rs
Xndless is offline   Reply With Quote
Old 06-05-2016, 10:45 AM   #2
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Any chance you got some bad gas? If so your engine would be cutting timing, combo of low octane and and reduced timing = reduced power. Just a thought.
HOJO is offline   Reply With Quote
Old 06-05-2016, 10:48 AM   #3
Xndless
Drives: 2013 2SS/RS
Possibly. I only noticed it after my dad went and filled up my tank, and then I went to drive my car a few days later.
Is bad gas bad for it? Is it damaging the engine at all? or is it just going to make it run like crap until new gas in put in the tank?
Old 06-05-2016, 11:06 AM   #4
keith.wilkinson.10
keith.wilkinson.10's Avatar
Drives: 2010 2SS/RS IBM
If it's gas once you get all the bad gas out and get good gas in do the fuse pull, 5 and 20.
Sent from my SAMSUNG-SM-G890A using Tapatalk
keith.wilkinson.10 is offline   Reply With Quote
Old 06-05-2016, 11:17 AM   #5
SPCBA
Drives: pleather and Chiclets
Stock tune? Just run all shitty like. Don't let dad fill it up anymore
SPCBA is offline   Reply With Quote
Old 06-05-2016, 11:29 AM   #6
Xndless
Drives: 2013 2SS/RS
All stock. Glad my car isn't broken, thanks!
Old 06-05-2016, 12:07 PM   #7
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
He might've put 87 octane in it. You should add a octane booster drive it around a bit then do the fuse pull over night
camarosspower is offline   Reply With Quote
Old 06-05-2016, 12:33 PM   #8
Gearheaded
Gearheaded's Avatar
Drives: 2014 SS
I bet he put the wrong gas in it. Does he have the reciept for when he filled it up?
Toys:
2014 SS - TSP 235/239, CAI, LT's, 12.2 @ 115 ("SLOWLY" chipping away ET)
2000 Trans Am - Bolt-ons 13.0@110 (sold)
2009 YZF R1 - Race bike (road course)(totaled racing)
2008 YZF R6 - Race bike (road course)(still own)
Gearheaded is offline   Reply With Quote
Old 06-05-2016, 01:02 PM   #9
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
If he did put 87 in it you're fine and just running on the lower octane table. Run it all out and just fill up with 91 or 93 (depending on your location) Then pull the 5 and 20 fuse for a few hours and it will reset to the high octane table and you'll get some power back.
Otherwise... make sure you have all the nannies turned off. Traction control will cause the issue you are describing too.
