10-07-2014, 10:24 AM | #1 |
Drives: 2010 2LT Victory Red Join Date: Oct 2014
Rack and Pinion Leak...
Does anybody else have this issue?
I have a 2010 2LT with only 7600 miles. I have a good mechanic! He does all my maintenance. I went for an OLF change and he showed me my power steering fluid was low and that there was a leak. He showed me the leak along the rack and pinion steering bar that started from the seal. He said not to worry about it now because it was so minor. He said he only needed to add a couple of tablespoons of fluid. But that eventually he'd have to change the whole part. I do have an extended warranty that expires in 2016 and I think the repair should be covered. Should I wait like he said or do the repair now? Could the bad roads where I live have caused the leak? Is it because I don't drive the car enough? What do you think? |
10-07-2014, 12:40 PM | #2 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Drain all the old fluid and ,Try some Lucas power steering conditioning fluid ,it may stop the leak or slow it down some . After 5 years your old fluid is shot anyway .
http://www.google.com/url?sa=t&rct=j...76943099,d.cGE
OLD GUY FLYING FAST AND LOW
10-07-2014, 03:41 PM | #3 |
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1 Join Date: Jan 2014
Why on earth did you spend good money on a great extended warrenty and not use it. I would ask your mechanic if he could take a picture of the leaking seal and write a report about the leak. Then take it to the dealer and have it replaced right away. The reason to have it done immediately is what if they replace the unit and then a hose starts leaking. Then at least you have time on your warenty to have the hose replaced.
10-07-2014, 04:04 PM | #4 |
Didn't see you had the extended warrantee . If it is in fact a leak they will fix it ,but if they claim it is not a leek just some minor weeping/dampness ,they may want to charge you half of a very inflated price to fix it . Do you have a deductible ?
10-08-2014, 09:54 AM | #5 | |
10-08-2014, 09:59 AM | #6 |
Thank you for your advice. No I have no deductible. If the mechanic says it's nothing to worry about at the moment, and that I can wait to the Spring when my next oil change is due(about six months from now) and check it out then... Does that sound reasonable? He is a very good mechanic. Could there be some hose damage in the future do to this problem as another poster mentioned to me? I'll ask him about draining and refilling with Lucas oil.
10-08-2014, 10:10 AM | #7 | |
Don't I notify the Grantor of my extended Warranty... They either look at the car and/or then contact my mechanic and they negotiate between them a repair price before any work is done. The warranty pays for the repair, right, I don't. And as I said I don't have a deductible. By the way according to my Warranty I can bring my car to whoever I want. It doesn't have to be to a GM dealer. |
10-08-2014, 01:43 PM | #8 |
All depends on the warrantee company ,there are some good ones and some bad ones . If there is no deductible ,that is a good start and you should be able to get it fixed right. Just make sure your warrantee company will allow your mechanic to do it and they will pay him directly. Still ,you should have changed the power steering fluid B4 this long . I like to change power steering fluid when it starts looking funky , every 3 years or 50000 miles witch ever comes first .
10-09-2014, 11:08 AM | #9 | |
I only have 7500 miles on the car. But I bought it in 2010 and it has been checked out on a normal regular basis. As of now I will heed my mechanics advice and wait till the Spring and see where I'm at then. In the meantime, I will check the reservoir from time to time and see if I get low on fluid. Thank you for your help... |
