06-20-2015, 03:04 PM | #1 |
Drives: 2010 Chevy Camaro 2SS/RS Join Date: Jan 2015
1st Time at 1/4 Mile... Kinda Embarassing
So my local Camaro Club had a big event today at the local 1/4 mile track including a car show, test n tune and a little bracket racing. Figured, why not run my car and see what it'll do. Best of only three passes I did was a 12.609 @ 120.55mph with a 2.084 short time. Embarassing part is the car has AGP's base TT kit at 9psi and a magnaflow catback making 588/593 to the wheels on my L99. The car is otherwise completely stock and obviously traction was the issue at that power level on the stock pirelli's and 21" wheels but geez. The thing literally spun thru the 330' mark and actually got sideways on the second pass at half track.
Obviously the car is capable of much better should traction and suspension be on point. I've got some BMR trailing arms and toe rods along with M&H 325 DR's and skinny fronts on order so judging by the mph I'm assuming the car will haul the mail once that all gets put on. I knew going into it that traction would be practically non-existent but I was at least expecting 11's lol
2010 Camaro 2SS
2010 Jeep Wrangler 2014 Ducati 1199 Panigale S |
06-20-2015, 03:13 PM | #2 |
Drives: Love the one you're with Join Date: Sep 2009
Don't look at it as a fail but rather a starting point. Learn from it and keep trying.
06-20-2015, 05:11 PM | #3 |
Emerald Coast Camaros
Drives: 2010 RS/SS Rally Yellow & 68 SS Join Date: Dec 2012
Tires and wheel will do more then all other for you. And that should put you in the high 10s low 11s with that HP
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135 AS OF 1/31/15 @ 633 RWHP=10.16@135 AS OF 1/29/16 @ 633 RWHP=10.10@136 TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF |
06-20-2015, 10:22 PM | #4 |
Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
Takes a lot of things to make a turbo package work at the track. Once you get the tires, boost controller, 2 step and the right converter you will be hard to beat.
Place your bets to guess the time when Unreal steps in. |
06-21-2015, 02:58 AM | #5 | |
Drives: 2015 Red Hot SS/RS M6 Join Date: Sep 2012
06-21-2015, 09:28 AM | #6 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
my cousin has a similar setup but with 12psi drag radials and a bunch of bmr suspension parts. best he could do was 11.5@125. it needed a converter or 2 step to build boost off the line
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
06-21-2015, 09:34 AM | #7 |
Yeah I agree a 2 step and a converter would be great for this car after the DR's and suspension pieces get put on. I was only launching at like 1200 rpm mainly because I knew I wouldnt be able to hook anyway but that only became more apparent when she was in full boost and on full tilt lol. But I'd hope for more than 11.5 @125, hell I'm not far from that spinning thru the first three gears lol.
2010 Camaro 2SS
06-21-2015, 12:11 PM | #8 |
When mine made 588 I ran 12.0s at 120 on street tires so your there on mph. Just gotta work on everything else.
06-21-2015, 12:25 PM | #9 |
Future Mopar Owner
Drives: 2011, 2SS/RS, Synergy Join Date: Aug 2012
Not surprised at all but you have a starting point. I am sure you probably were though based on the claims of the kit "running 11's on a stock motor".
Did you build the car with aspirations to run the 1/4 mile? Have you drag raced before?
2005 GTO-IBM-A4-Sold
2011 Camaro SS/RS Synergy-1 of 255-Sold You will be missed but you are in good hands! 2019 Challenger Hellcat B5, Redeye, Widebody |
06-21-2015, 12:50 PM | #10 |
Drives: 2012 Camaro 1SS M6 Join Date: Sep 2014
06-21-2015, 03:38 PM | #11 |
My goals were more of a street beast than a 9 second car when I started out. I knew she would spin but I figured low 12's weren't out of the question and was hoping this thing would pull mid 11's with proper tires, a few suspension pieces and a drop of meth in the mix. I have a good bit of experience in drag racing purpose-built sportbikes but it's a bit different in an automatic TT V8 car.
2010 Camaro 2SS
06-21-2015, 08:03 PM | #12 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
I would say it has to be capable of much more. I'm running twin turbos on my V6 with around 450whp of so and I'm running low 12's and trapping 119 on general gmax all seasons with about a 2.1 60ft. I really want to get high 11s with no meth and no drag radials, just the turbo kit on an otherwise Stock v6(exept exhaust).
3.6L Twin Turbo V6 Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension 10.75 @ 131mph |
06-22-2015, 11:52 AM | #13 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
At your power level it's difficult to hook on street tires, and sometimes, well, the cars can spin so bad it's kinda dangerous.
Once you get the DRs on you will be much happier.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
06-23-2015, 08:34 PM | #14 | |
Yeah I'm super anxious to get the skinny fronts and drag radials on and see what that alone does for the car. It definitely got sketchy on me, like I said, on the third pass (which was the last pass of the day because of it) she got loose on me and got pretty sideways at about half-track. I think between the fact that I can't use the first three gears/the first 330ish feet of the track, and these 21's are heavy as all hell, the times should come down quite considerably once I go with the light Weld wheels and sticky tires. Toss meth and suspension in the mix and I'm hoping for at least mid 11's.
2010 Camaro 2SS
