09-07-2010, 12:16 PM | #1 |
June '10
Drives: '10 2SS/RS RJT Join Date: Jul 2009
How to tell if you have holes behind your rear bowtie
Tools you need
Scraper Claw Hammer Trunk Lid What to do Note that the cover is angled down for when you go to replace it Slide scraper behind plastic cover between cover and trunk lid carpeting Pry towards yourself Do the same thing on this side (when popping this side make sure to hold the cover so it doesn't fly off) Pry towards yourself Plastic tabs on trunk latch cover Slide scraper behind plastic pin between pin and trunk lid carpeting Pry towards yourself Slide claw of hammer between plastic pin and carpeting Tap hammer end with hand so plastic pin slides between claw Pry towards yourself and pop the plastic pin out There are 11 pins in total Next you need to remove the emergency trunk release handle, pull carpeting out and towards yourself then up While pushing up on bottom of carpet pull down on emergency trunk release handle Flip handle over Tip handle down to remove metal pin from back of handle Place finger behind metal pin and push towards yourself Metal pin should pop out Pull carpeting up and towards yourself letting metal pin slid through the carpeting Bare trunk lid Left side Plastic pin :( Right side Plastic pin :(
09-07-2010, 12:21 PM | #2 |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
2010's have bowtie guide pins, 2011's do not.
09-07-2010, 12:24 PM | #3 |
June '10
Not always, here are a couple people with May builds that did not have mounting holes. My car is also a May build and built a couple days after theirs were built and mine does have holes.
09-07-2010, 12:25 PM | #4 |
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
It appears some late 2010's don't have the holes as well. http://www.camaro5.com/forums/showthread.php?t=100459
09-07-2010, 12:34 PM | #5 | ||
Go Blue!!!!!
09-07-2010, 01:05 PM | #6 |
Drives: fanboys and ass kissers crazy. Join Date: May 2008
Great play by play Josh!
04-09-2011, 06:03 PM | #7 |
Drives: 2011 Synergy LT RS Join Date: Mar 2011
so mine being an '11 built in october of '10 would not have the pins? and whats the best way to get the 3M residue off? what about re-application?
04-09-2011, 06:40 PM | #8 |
knows 2 facts about ducks
Goo gone gets it off. Then just use double sided 3M tape to put it back on.
04-10-2011, 11:38 AM | #9 |
I have no life
Drives: 06' Subaru STI, ex-Camaro V6 LLT Join Date: Apr 2010
cool DIY =D
04-10-2011, 12:42 PM | #10 |
Steve from Canada.
Drives: 2010 SW SS/RS with Inferno package. Join Date: Mar 2009
I removed my trunk lid liner yesterday to install my MPD spoiler but didn't find this thread until last night.
So I took it off again this morning hoping to not find the bowtie pins but they are there. Thanks to the OP for letting me know how to find out. BTW, not that's it's a big deal but there is a slot in the liner so you don't have to remove the emergency release handle if you don't want to.
04-10-2011, 08:38 PM | #11 |
Camaro Crazy
Drives: 2010 1SS/RS IBM/Grey M6 Join Date: Jun 2010
my 2010 had them
04-11-2011, 08:53 AM | #12 |
Drives: 2SS/RS - Black - GFX Join Date: Nov 2008
Why dont you guys try to find out the VIN cutoff?
It would be much easier to check your VIN.
Ordered: 10-13-08
Built: 3-30-09 (#1691) Recieved: 6-12-09 Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods. Last edited by Bell040; 04-11-2011 at 01:06 PM. |
Similar Threads | ||||
How to remove gold center from rear bowtie | SSyanide | Cosmetics and Lighting Modification Discussions | 20 | 03-12-2012 07:33 PM |
rear bowtie chrome peeling | or55bbeauty | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 2 | 06-29-2010 12:11 PM |
Im sure this has been asked before.. But forgive my innocence :) | gmag21 | Suspension / Brakes / Chassis | 23 | 02-21-2010 10:29 PM |
Center of rear bowtie coming unglued??? | My2SS/RS | Cosmetics and Lighting Modification Discussions | 5 | 02-03-2010 02:00 AM |
How does the rear bowtie emblem come off? | bumblebeecamaro | Cosmetics and Lighting Modification Discussions | 13 | 01-23-2010 12:57 PM |
