Old 12-12-2013, 07:22 AM   #1
huitt06
huitt06's Avatar
Drives: 2011 L99 SS
L99 underdrive install
Should be in today, any tips or advice on install?
TSP 1 7/8, CNT catback, VMAX, CAI intake, ADM scoop, 3.70s, Adm Tuned(374/391), SLP UDP, 18" nurbs/NT05r's , 3200 stall, Granatelli trailing arms....1/4 mi best 12.7
huitt06 is offline   Reply With Quote
Old 12-12-2013, 07:33 AM   #2
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
Ok,
removal is easy. install requires a special tool AND NEW crank bolt.
The install tool is basically a length of threaded rod with washers that helps push the pulley into place. I went to 3 places before I ended up at a dealers- they were the only place that had this tool.
Use the OLD crank pulley to properly position/space the UD Pulley, then remove and install+torque the new crank pulley.
BE CAREFUL during install, Pulley sits directly in front of the AC compressor. The dealer broke the compressor and had to replace it during my install, so damage to the AC unit can occur,
Good luck, let us know how it turns out
OH, and make sure the belts all fit BEFORE removal of old belts- found this out the hard way.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 12-12-2013, 07:50 AM   #3
jvoisel
Drives: 2010 2SS/RS M6
Originally Posted by Spartan01 View Post
Ok,
The install tool is basically a length of threaded rod with washers that helps push the pulley into place. I went to 3 places beofre I ended up at a dealers- they were the only place that had this tool.
Looks like you mixed a few words up in there lol.
Take belts off, remove crank bolt, drop a large extension inside crank so you dont damage threads.. I use a 3 jaw puller, put the tip in end of the extension and remove pulley. A balancer install tool is the best way to get the new one back on. Once you have it on and can thread the OLD bolt back in a good ways, torque it down to seat pulley. Remove old bolt and install new, torque to spec.
Here's the tool I use..
https://sdparts.com/details/scoggin-...-center/sd6628
Easy to make your own, or some people put a block of wood on the pulley and hit it dead center to get it started.. DO NOT use the stock bolt to get the pulley started. Goodluck!
2010 2SS/RS
jvoisel is offline   Reply With Quote
Old 12-12-2013, 07:55 AM   #4
jvoisel
Dude, who are you? The F-Ing grammar police?
Calm down buddy.
2010 2SS/RS
Old 12-12-2013, 07:59 AM   #5
tanur420
Drives: 2011 Camaro SS
I went to fastenal and got a peice of allthread some washers and nuts and made my own install tool for about 20$
tanur420 is offline   Reply With Quote
Old 12-12-2013, 10:21 AM   #6
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
These are the correct removal and installation tools. Do not use a crank bolt to install the pulley. Chances are you will pull out all the threads in the crank.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
Old 12-12-2013, 10:24 AM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
NO POWER tools
Old 12-25-2013, 08:30 AM   #8
huitt06
huitt06's Avatar
Drives: 2011 L99 SS
Bit late but thanks guys ...got her on and enjoying it.
Old 12-25-2013, 08:41 AM   #9
chozn4service
chozn4service's Avatar
Drives: 2016 SS w/2SS A8 Blue Velvet
What does this do? Just got L99 4 months ago... Thnx!
Never grow up, it's a trap!
chozn4service is offline   Reply With Quote
Old 12-25-2013, 09:14 AM   #10
huitt06
huitt06's Avatar
Drives: 2011 L99 SS
slight power increase and better response...not bad install with right tools...i would suggest headers and tune first tho...L99 tuned is a different car
Old 12-25-2013, 09:18 AM   #11
chozn4service
Thanks for the info! Yea I was going to put some Solo HFC on it so I wouldn't have to tune but since my warranty is out next year, I'm going to forego the cats and do headers, either Pfadt or Kooks and have it tuned. I guess I'll probably have them do the U/P at the same time.
Old 12-25-2013, 09:48 AM   #12
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
Originally Posted by jvoisel View Post
Calm down buddy.
Lol
MARINE1991 is offline   Reply With Quote
Old 12-28-2013, 12:51 PM   #13
LeanPocket
Drives: 2010 2SS
I used an impact to remove and install the crank bolt.
removed the electric fans
Removed crank bolt with impact
Used pulley remover tool
Put new pulley on and used a wood plank to tap it in
Impacted new bolt in
Use a knife to cut the ac belt.. Much easier
And have a friend help blip the belt onto the new pulley.
LeanPocket is offline   Reply With Quote
Old 12-29-2013, 12:57 AM   #14
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
dont tap on your pully. would you tap on your thrust bearings in your motor with a hammer? thats what your doing when you tap on your crank
JCunningham is offline   Reply With Quote
