05-17-2010, 07:13 PM | #1 |
Drives: '10 Camaro 2SS,04 Colorado,06 ZX6R Join Date: May 2008
PINKS
I am going to get pics and video of PINKS from Maple Grove Raceway this past weekend soon. Look at this thread for them.
The end result was I qualified in the B class (12.00 - 12.49) with a 12.24. However they picked the high 9 class as they had 32 cars within .02 of each other. I do wish for anyone with advise on not having ABS kick in during a burnout to chime in. When I burn out it keeps kicking in and I lurch forward, and it pretty much ruins the burn out. I have tried pulling the fuse but I can't turn TCS off then.
Vararam CAI, ARH Headers, Flowmaster Exhaust, Nitto NT555Rs, Custom CAM and Tune - 11.981 @ 116.27
IOM - 2SS/RS - Auto - IAP - Sunroof - Ordered 10/13 (#7 at dealer) 3000(accepted to production ): 4/19/09 3300 (scheduled for prod ): 5/11/09 3400 (broadcast ): 5/16/09 3800 (produced ): 5/22/09 4150 (invoiced ): 6/01/09 4200 (shipped ): 6/01/09 5000 (at dealer ): 6/12/09 6000 (delivery to me ): 6/12/09 |
05-17-2010, 09:41 PM | #2 |
2010 Camaro 2 SS/RS M6
Drives: 2010 Camaro SS/RS Join Date: May 2009
have you tried holding down the tc button for 10 seconds until both light come on, on the dash?
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
05-18-2010, 10:01 AM | #3 |
Yep, ABS still kicks in unfortunately
05-18-2010, 10:05 AM | #4 |
Drives: 2010 2SS RS Red Jewel Tint Join Date: Apr 2010
Would going to the "Competitive Mode" where you hit the TC button twice help? It's supposed to optimize launch.
Kooks 1 7/8 LT Headers / K&N High Flow Intake / Magnaflow competitive X-pipe Cat-Back / Tune / 3M Clear Bra Protection
05-18-2010, 10:06 AM | #5 |
The DIC will flash "Competitive Mode" if you are in that mode.
05-18-2010, 10:47 AM | #6 |
Drives: '10 LT RS A6 & '04 Acura RSX Type S Join Date: Oct 2009
Try driving around the water and back up to it once you get lined up. No water on the front tires should help.
05-18-2010, 10:56 AM | #7 |
That ABS coming on is part of the stabilitrac system and comes on if you have shorter tires on the rear. Be careful it can cause you to have no brakes at the end of the track!
[SIGPIC][/SIGPIC]Va.Speed built 427 stroker
LS2 Darton sleeved 427 stroker.Callies dragonslayer crankshaft. Callies I beam rods. Wiseco blower pistons. Mast cnc 12 degree big bore ls3 heads-2.2 intake &1.6 ex. 6 bolt 270cc-.750 deck. Lunati link bar lifters.T&D roller rockers.COMP-VA. Speed special cam 605 lift, 238dur. Procharger F1R @15psi. ARH headers with custom 3'' exhaust all the way.Magnaflow mufflers. QTP cutouts.Rossler built 6l80e trans. DSS 1400hp axles. Pfadt suspension.-Coilovers, sway bars,motor mounts,trailing arms. Aeromotive eliminater pump. 907rwhp. |
05-18-2010, 02:35 PM | #8 |
But I disable stabilitrac, holding the button down for 8-10 seconds. It shouldn't engage in that case... but it still does. Once I get video up you will see how my car jumps forward while warming up the tires because of ABS
05-18-2010, 02:35 PM | #9 |
Competitive mode keeps TCS enabled - won't let me warm up the tires that way therefore worse than with the ABS kicking in
05-18-2010, 02:40 PM | #10 |
that sux
05-18-2010, 02:44 PM | #11 |
The best chance will probably be a line lock
05-18-2010, 02:46 PM | #12 |
Pics taking by Pinks Photographers
05-21-2010, 08:37 AM | #13 |
Just a few pics I got over the weekend
05-24-2010, 01:07 PM | #14 |
Heritage Hanger
Drives: 2010 Camaro 2SS/RS, Black. Join Date: May 2009
Well I don't have any advice.. but great pics!
Keeping The Spirit Alive! |
Similar Threads | ||||
WANTED: Funding for Pinks All out | RickyTheStorm | Members Classifieds - Non-Automotive | 4 | 03-23-2010 11:06 AM |
Pinks all out pics | Iroczlover | General Automotive + Other Cars Discussion | 0 | 08-18-2009 12:30 AM |
Pinks all out | Iroczlover | Off-topic Discussions | 50 | 05-31-2009 07:43 PM |
PINKS... | KILLER74Z28 | Off-topic Discussions | 11 | 05-10-2008 05:12 PM |
Pinks! LS1Tech.com Camaro | acscamarochick06 | General Automotive + Other Cars Discussion | 8 | 08-12-2007 04:19 PM |
