02-24-2017, 09:46 PM | #1 |
Drives: 2016 Chevy Camaro Join Date: Feb 2016
Front drivers side speaker cutting out
Hello all!
I have an issue I need the dealer to help with but I'm having trouble figuring out where it is coming from. When I hit bumps in the road my front drivers side speakers will cut in and out and make a sortof "crackle" when they do. First, has anyone experienced this? Second, I have trouble figuring out if it's the one in the dash or the door. I have the 1LT V6, is the dash on the left of the gauges just a tweeter? Or is it a full range speaker like the door? This usually happens at speed and usually it cuts out for only a few seconds, though I had it cut out for about a full min when I was on the freeway the other day but I was not able to pull over fast enough to find out what speakers were not working. Whiskey |
02-24-2017, 11:50 PM | #2 |
2016 Camaro 1LT 2.0T
Drives: Nemesis Join Date: Feb 2011
Flaky speakers are common on the 6th gens. I've had the issue and had it fixed under warranty.
02-25-2017, 12:02 AM | #3 |
Drives: 2020 Camaro 2SS Join Date: Aug 2009
Door speakers are just bass.
02-25-2017, 09:20 AM | #4 | |
Drives: 2017 Camaro 1LT HBM Join Date: Sep 2016
Sorry could not resist. |
02-25-2017, 07:59 PM | #5 |
Drives: 67 goat, 69 goat ram air III Join Date: Mar 2009
02-26-2017, 02:33 PM | #6 | |
Drives: 2016 2SS Join Date: Mar 2016
02-27-2017, 08:06 AM | #7 |
Drives: 16 1SS White M6 Join Date: Apr 2016
I have the same problem with the dash speaker. For me, it's most prevalent/noticeable with the door chime.
Naturally, dealer couldn't reproduce the issue. I will wait a little longer, put some more miles on it and hope to nail down more specific circumstances where the crackling issue can be recreated easily. |
02-27-2017, 09:18 AM | #8 |
Drives: Civic Join Date: Nov 2016
To people facing this issue. Is this happening with all speakers or only non Bose speakers?
02-27-2017, 09:23 AM | #9 |
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP Join Date: Jan 2016
The dealer is going to have a hard time troubleshooting an intermittent problem like this. Nowhere will it be logged which speaker was affected. Best you wait until you have a better idea what is going on. The dealer is not going to take everything apart and check connections if they don't know where to start. So don't waste your time.
02-27-2017, 11:18 AM | #10 |
Deadpool
Drives: 2016 camaro lt rs m6 redhot Join Date: Sep 2016
I have the same issue mine has the boae system and it seems to be the speaker on the dash close to the windshield on the driver side,are these hard to remove,does the whole dash have to be removed to get to these,i know i can just take to the dealer and have it fixed but would like to know how they are removed
