12-07-2013, 08:40 PM | #1 |
Drives: 2021 2SS 1le Shock Join Date: Feb 2011
Broken security lug nut
1234
12-07-2013, 09:08 PM | #2 |
Let's go Rangers!
I have no answer to your question but id like to know what the point was of putting what a rim costs?
Sent from my 2SS/RS |
12-07-2013, 09:17 PM | #3 |
Drives: 2011 SS (Sparrow Spearer???) Join Date: Aug 2013
What exactly snapped flush? was it the stud(the threaded part that comes out thru the rotor center)? If its that, then you should still be able to take the other lug nuts off and pull the wheel.
BTW why is the dealer doing this? Do you not have the tools/know how?
Black magic woman, don't turn your back on me baby!
12-07-2013, 09:26 PM | #4 |
Drives: 13' Sw 2ss Ls3 Join Date: Dec 2012
Could b possible they wont damage the fin8sh on the wheel if done right I use to help out a buddy at his wheel shop and we had this socket that would go over the lug nut or what was remaining of it and had to hammer it on then impact it off worked great
12-07-2013, 09:47 PM | #5 | |
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
12-07-2013, 09:59 PM | #6 | |
Account not blocked
well i guess nobody was going to steel those wheels |
12-07-2013, 11:02 PM | #7 | |
2010 2SS RS
Drives: 2010 2SS RS (L99) Join Date: Aug 2013
+1
But obviously because other rims are inferior Quote:
Sent from my iPhone using Tapatalk - now Free
~ Build Thread | 371HP & 390 TQ
Performance Mods: K&N Cold Air Intake | Pypes Cat-Back Exhaust | Aluminum Paddle Shifters | VaraRam Wedge | Cross Drilled/Slotted Rotors | Hawk HPC Pads | M.M. Ported Throttle Body | Kooks 1 7/8 Headers w/ High Flow Cats | Dyno Tune @ RPM Cosmetic Mods: Rally Stripes (style1, style2, style2.2) | Splitter | Painted Calipers | Door Projector Lights | Front-Emblem Delete | Cup Holder Lighting | Quarter Window Covers | Phantom Grille | Ghosted Side Markers | Tinted Fog Lights | ZL1 Rockers | Tail Light Bezels |
12-07-2013, 11:35 PM | #8 |
Drives: 2012 2SS/RS Convertible Join Date: Aug 2012
the easiest and cleanest way to remove it is to have an experienced welder weld another lug to it so you can get it off.
I had something similar happed to a previous car, and the break was way down inside the lug area.. The guy that does my exhaust and has for several cars was able to weld another lug nut to it from the inside of the lug (the inner threaded area) and not damage the wheel at all, then we used a good size breaker bar to get the lug off.. be sure they don't weld it to the stud, only to the broken nut.. (hence why I say an experienced welder, not just someone that knows how to operate a rig) hope that helps.
I'm only responsible for what I say, not for what you fail to understand.
