Old 07-28-2013, 10:35 PM   #1
Arrond
Drives: 2013 Camaro 1SS/RS/1LE/NPP
Hood Wrap Issue
So I tried to VRT my hood wrap tonight and it looks terrible. Are there any suggestions on how to completely remove the VRT from the hood.
Arrond is offline   Reply With Quote
Old 07-28-2013, 10:38 PM   #2
Jc's1LE
Drives: 2015 SW 1LE BA NPP Recaros
I use mothers reflections on my hood try a warm cloth on the hood first
Jc's1LE is offline   Reply With Quote
Old 07-28-2013, 10:47 PM   #3
Arrond
I have tried wiping with warm water and dish soap and water with no luck.
Old 07-28-2013, 10:53 PM   #4
Jc's1LE
what does it look like ?
Old 07-28-2013, 11:00 PM   #5
t&t moyer
It's all hers.
t&t moyer's Avatar
Drives: 2015 ZL1
There's an isopropyl alcohol solution that is recommended for cleaning. I've seen it posted / recommended here and elsewhere by vinyl wrap folks. Google and see what you come up with.
t&t moyer is offline   Reply With Quote
Old 07-28-2013, 11:04 PM   #6
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
How did you do it? I use a sponge block for detailing and sparingly and meticulously work the VRT in back and forth in one direction.
It evens out after about a week and a couple washes.
If you are set on totally removing it, try a detail spray and work it in sparingly, rubbing diligently. If that doesn't help try a diluted citrus cleaner and keep it off the paint and from drying.
Be patient with the VRT and yourself. It's tedious but will work out in the long run. Always detail in the shade. Avoid sun at all costs.
Sent from my iPhone using Tapatalk 2
2013 1LE NPP GBE
Mods
Track Days
CrystalRedTintcoat is offline   Reply With Quote
Old 07-29-2013, 12:47 AM   #7
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
After a few cleanings it will lose the shine.
Otherwise, for cleaning when it's extremely dirty: http://www.amazon.com/Meguiars-Heavy...I1FWWK7VQ4VCAC
and for normal use: http://www.amazon.com/Meguiars-Vinyl...I24D1RQQI0JMU3
JimE is offline   Reply With Quote
