09-27-2010, 11:38 PM | #1 |
Drives: 2010 Camaro 1LT Join Date: Jan 2010
Springs for my 1LT?
So I want to drop my 1LT by about 1" all around. I don't mind a very slight difference between the front and rear but don't want to drop it too much (my fiance already complains about stock haha). Anyway, I was looking for a good lowering spring and wondering if I could get any suggestions. Thanks.
09-28-2010, 12:18 AM | #2 |
They're all good. Eibach is the cheapest. Pfadt and Pedders have the best reputation. It's up to you how much you want to spend. Everybody will tell you whichever one they have is the best. I don't think you can make a bad choice, as I went with the cheapest one and have been very satisfied.
[B]
09-29-2010, 10:00 PM | #3 | |
Drives: Camaro Justice Join Date: Jun 2007
Pedders coils trade at a premium price and with good reason.
The key to Pedders spring excellence is manufacturing quality typified by precision in loaded height tolerance. Typical in the industry is a loaded height variation of +/- 15mm of roughly 5/8s of an inch. Pedders thinks that is unacceptable. Pedders lowering coil tolerance is +/- 1mm. Pedders load cell verifies EVERY SportsRyder coil we make to meet this standard. Coils that do not 'measure up' are sent to the scrap metal recycling yard which is as unusual as our +/- 1mm tolerance. Brand -X Coils Pedders Coils For you ride quality will be critical along with NO SQEAKS They are a modest drop and will work exceptionally well with the OE dampers. If you want to go lower we believe that Xa coilovers are the correct solution. We think the OE engineers are bright guys. They designed a highly progressive 5th Gen bumpstop so that when the suspension compresses into the bumpstop the motion is smooth and controlled resulting is a high level of ride quality. Cutting the bumpstop makes the bumptop less progressive which is stating the obvious and there is no need to describe the result. With a Pedders set of coils you will not have to cut bumpstops. What you are paying for is premium quality and premium performance and premium ride quality. You should select the slightly higher rear coil to deliver the best possible lowering coil ride the 220032 and 220035 and keep your fiance happy. |
Similar Threads | ||||
Pfadt Race Engineering Lowering Springs Improve Looks And Performance. | Apex Motorsports | Suspension / Chassis / Brakes | 341 | 02-02-2014 11:52 AM |
BMR Lowering Springs - How It's Made | BMR Suspension | Suspension / Brakes / Chassis | 40 | 06-22-2010 10:32 AM |
Maximize Your Suspension ~ Hotchkis Swaybars, Springs and Chassis Braces! | Circuit Motorsports | Suspension / Chassis / Brakes | 99 | 05-24-2010 04:21 PM |
