05-20-2011, 05:23 PM | #1 |
Drives: 2011 2SS/RS LS3 Join Date: Apr 2011
Need new clutch
Well its time to upgrade my clutch set up... I want to get a set up that will handle all the rest of my engine mods + a lil more ..cam will be the next mod going in .. anyone already replaced theirs want to help with some advice.. I would like to keep it as much as possible like the way the stocker feels..Best bang for the buck....
2011 SS/RS M6 Synergy green 559RWHP...530RWTQ
Mods: Maggie supercharger...LS9X Twin disk clutch..85lb Fast inj..ZL1 Fuel pump..,MSD BAP..Roto-Fab cold air..Hotchkis max chassis brace, strut brace,, sway bars front and rear ,HD end links.adj toe link,lower control arm,,trailing arm,, Norris catch can..XS Power 1 7/8 ss lt headers..3" cat delete..3"X pipe..XS 3" mufflers. Hurst shifter.. Lowering springs..22" Foose wheels. Boost/vac ..Fuel pressure gauge..GPS stereo Head unit, all speakers and amp 4 10" subs..Ram air hood.heat extractors .Custom leather interior.Escort 9500ci.. |
05-20-2011, 05:26 PM | #2 |
50 Shades of Prey
Drives: TT/SS Join Date: Oct 2010
Ls9r
Futral Motorsports built and tuned
05-20-2011, 06:44 PM | #3 |
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm Join Date: Feb 2009
Centerforce twin disc, best clutch out there, will hold 1200 ft lbs of torq. pedal pressure is 3 lbs less than the stock one. i have over 12k on mine.
URR2SLO - If you're not going fast enough, get out the way......
05-20-2011, 06:56 PM | #4 |
Drives: 2010 2SS/RS IOM/IOM #3625 Join Date: Jun 2008
LPE ZR1 twin disc is getting good reviews
666 EVIL RWHP BUILT AND TUNED BY SHIFTED PERCEPTIONS INC.(SPi)
416 Forged Stroker, E-Force Supercharger, Blower Cam, Rotofab CAI, Stainless Works 2" LT Headers and 3" Exhaust, LPE ZR1 Twin Disc Clutch, DSS 1400 HP Axles, Pfadt Performance Kit Stage 3. |
05-24-2011, 02:31 PM | #5 |
Drives: 11 2SS/RS E-Force Supercharged Join Date: Apr 2010
I went with the ACT twin disc. Love it. Feel pretty much stock but it actually holds. My stock one was slipping at my power level.
05-24-2011, 03:40 PM | #6 |
Love my spec supertwin st. Will hold more then you'll ever make and drives surprisingly well.
05-24-2011, 03:44 PM | #7 |
Drives: Silver 2010 SS Camaro Join Date: Jul 2009
What is the LPE ZR1 clutch good for as far as horsepower and torque?
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
05-24-2011, 06:05 PM | #8 |
Drives: 2006 Z06, 2015 Z06, 2014 Silverado Join Date: May 2011
I have the Katech version of the LS9 clutch (alum flywheel instead of heavy steel) in my 582 rwhp Z06 that we race every weekend. I've been running it for 1 1/2 years without issues. I consistantly rip off 1.5 and 1.6 short times on drag radials all night long. it has a stock pedal feel, no chatter and has been able to hold all that I've thrown at it.
05-25-2011, 10:38 AM | #9 | |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
|Blair |
05-25-2011, 10:53 AM | #10 |
I have read that on the aluminium flywheel it has to be heated for the initial clearance to be set up.. is this what you have found on yours
05-25-2011, 11:37 AM | #11 |
Not sure about HP but they list 960+ ft-lbs torque capacity.
05-25-2011, 12:24 PM | #12 |
Drives: cars Join Date: May 2011
You just stick it in the oven for a few minutes when the wife isn't home. It expands the aluminum a bit and lets it go in place properly.
05-25-2011, 01:34 PM | #13 |
but she will know!!! they always find out !!!
05-25-2011, 01:56 PM | #14 |
Get a LS9 setup from Richie. Great clutch.
Just throw it in the over at 200F for 30 minutes.
Nick
Corvette Z06 -1200ish rwhp |
Similar Threads | ||||
I want a new clutch, you too????? Sign here | tjbusa | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 370 | 08-10-2013 03:27 AM |
clutch pedal repeatedly stuck, minimal load | cab2g | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 2 | 04-26-2011 09:39 AM |
What exactly burns the clutch on an m6? | DarkneSS | 5th Gen Camaro SS LS LT General Discussions | 49 | 04-15-2011 10:55 AM |
Clutch being replaced | MillerTime | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 29 | 10-25-2010 04:37 PM |
Oil Change Ramp | mjlash22 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 17 | 01-21-2010 10:40 PM |
