11-12-2011, 08:05 PM | #1 |
Don't ask to pop my hood!
Drives: it's loud....... Join Date: Jun 2011
Left front strut ....
Hi All,
Just lowered my car other day, went to take it get aligned yesterday but they couldn't do it cause i need the camber kit which i ran down to our local napa and bought them, ( just for fronts ) now have to wait till monday to get aligned and kit put in, but i notice my left front strut when i turn or just going slow over bumps makes a ( kinda hard to explain the sound ) like squeeky old door sound when everything is lined up fine no rubber bushings left out or anything, Shop said might take a few days or so for them to settle? Anything else i can check for? Thanks *EDIT* Do you think after alignment the sound will go away? Pics added in album how it looks... sorry taken with cell..
Limo tint rears, 35% sides | B&G lowering springs | BowTies Blacked out | Red Footwells|Dome Light|Kicker 500Watts-Amp-Kicker 12" Ported Sub=BOOM| Stillin Splitter |Pssst 100 shot| 13.36 @102.7 @LVMS | 2010. |
11-13-2011, 06:59 AM | #2 |
check the rubber bushing/washer at the top... it may be missing which has been the cause of similar sounds.
11-13-2011, 07:04 PM | #3 |
Drives: 2014 Z28 camaro Join Date: Sep 2009
I would recheck the left front strut mount and the spring to make sure it is seated properly before the alignment,an alignment probally won't fix a noise or anything else since it is just the final adjustment.There should be no need for a camber kit on the front as it is adjustable from the factory, you just need a bolt to screw into the knuckle while the adjustment is being made then remove the bolt after the camber is adjusted.
Similar Threads | ||||
CAMARO WIKI | Tran | Wiki | 66 | 04-22-2024 11:41 AM |
2011 Camaro front strut tower brace | yellowbird | Suspension / Brakes / Chassis | 13 | 01-11-2011 11:38 AM |
MTI Racing Strut Tower Brace | MTI Racing Kevin | Suspension / Brakes / Chassis | 0 | 06-28-2010 12:57 PM |
We need help with Electronics wiring diagrams | 2SSRS@Gen5diy | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 11 | 12-13-2009 05:58 PM |
