07-12-2015, 09:52 PM | #1 |
SS vs 1LE Rear End Feel/Noise
Ok, so I have about 200 miles on the car so far. When I am on the highway, it is almost like I am hearing rear end whine, but only on the highway. My question is, is this normal for the 1LE rear end/3.91s? Am I just so used to the stock SS rear end that I am making a big deal out of nothing? The car is smooth, no vibration with my perceived noise. Just making sure I am not
2015 Red Hot 1SS/RS/1LE
ADM LSA kit BTR Stg3 PD Cam Stainless Power LTs w/ CATs Stainless Works ZL1 Res. Delete 3" Retro Catback DST Ported ZL1 TB 619RWHP / 539LB-FT |
07-12-2015, 10:26 PM | #2 |
Drives: 2015 Redhot 1LE Join Date: Feb 2013
Time to change the rear differential fluid
07-12-2015, 10:49 PM | #3 |
So soon? Car only has 200 miles. What fluid would you guys recommend?
07-12-2015, 11:21 PM | #4 |
Drives: 1969 Z28, 1982 Z28, 2014 SS/RS/1LE Join Date: Nov 2013
It is your tires. They are quite noisy. Rear end should not be making any noise and certainly does not need a fluid change. I hear the same whine...bugged me at first thinking it was gears or trans. Then figured out it is tire noise.
07-12-2015, 11:37 PM | #5 | |
http://www.camaro5.com/forums/showthread.php?t=299450 http://www.camaro5.com/forums/showthread.php?t=248463 http://www.camaro5.com/forums/showthread.php?t=233565 http://www.camaro5.com/forums/showthread.php?t=309102 You can search the forums with people having similar problems Maybe im wrong who knows |
07-13-2015, 10:08 AM | #6 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
I had no whine and changed fluid at about 28K. It was between the hard use and normal use recommendation in the owners manual. If you have rear end noise, and only have 200 miles on the car, I would take in in because it is not normal. I have also not found these tires to be all that loud. Tires make different sounds on different road surfaces, so if this is a consistent whine, I would get it checked out.
07-13-2015, 02:30 PM | #7 |
The Rear end is not going to make a whining noise unless the car is moving...same with the tires. Makes it a bit harder to discern where the noise is coming from. I had rear end gears go out on me when I raced dirt late model and let me tell ya, when they whine...it is LOUD! Could here it over a 765HP open header alky motor! LOL if you have a slight whine, I bet it is tires. But...as others have said, take it in and get it checked out. Maybe not all sets of these tires whine. I can tell you that mine do. More on some roads than others. More so on newer smoother pavement for sure. Good luck and let us know what you find.
07-13-2015, 04:25 PM | #8 |
Drives: 2019 Chevy Equinox Premier AWD Join Date: Mar 2011
I had what sounded to me (and felt like) transmission noise and/or gear whine and the car was hard to shift. I took it into the dealer to get it checked at around 250 miles or so (I'll check later for actual mileage) and they had the car for 1 week. They replaced the rear bearings and seals due to (what they said was) excessive play and they put in new full synthetic gear fluid (the same type used in the ZR1 corvette.) All under warranty. Ever since then, the drivetrain is still a bit noisy but not near as bad.
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43) |
07-13-2015, 06:23 PM | #9 | |
Drives: ‘13 1LE Join Date: Jul 2013
I too don't find the 1LE's G2 tires that loud as gajagfan mentioned already. At 200 miles, time for immediate warranty action, before you elect to experiment with other diff fluids. Do yo Fwiw, my previous BMW exhibited slight rear whine. This car does not, so I know how to discern. Hopefully you do as well. The fact your previous SS did not raise the red flag in your head is reason enough to act ASAP IMHO. |
07-13-2015, 08:29 PM | #10 | |
GM and Tremic engineers are smart guys. The fluid specified for the rear end and trans in these cars is tested and proven. However, there is definitely a chance the rear end gears can be set slightly wrong given lash is important and high volume production of said gears...you could have some with bad lash settings from the factory. The fact that all the mechanics of these cars, in mass production, can be that well tuned and tight. It is truly a work of art in reality. |
07-14-2015, 09:57 PM | #11 |
Thanks for all the input guys. I spoke to the dealer and now just got to set up a time to take it in. I just wanted to know from you guys here if something like this was normal for a 1LE. Now that I know that it's not, she's going in.
07-15-2015, 09:43 AM | #12 | |
(1 of 43) |
