12-15-2013, 12:53 PM | #1 |
Taeng
Diff fail!
As I was filling up my differential, a 2-inch piece of plastic tubing slipped inside!
What do I do now! I cannot take the differential apart!
12-15-2013, 12:55 PM | #2 |
Drives: 2013 Camaro 2SS/RS BRM LS3 Join Date: Jan 2013
Wait until the differential chews it up into little tiny pieces, then change your fluid again
12-15-2013, 12:56 PM | #3 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
You have no choice but to pull the diff out. It's not that hard to do.
12-15-2013, 12:57 PM | #4 | |
In The Circle
That could be risky.
12-15-2013, 01:03 PM | #5 |
Drives: 2010 Camaro SS Join Date: Oct 2013
Beg, borrow or steal a Borescope Endoscope and go fishing with a piece of wire.
These scopes are getting cheaper all the time.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
12-15-2013, 01:22 PM | #6 | |
Drives: 2010 2SS/RS IBM Join Date: Dec 2013
Yeah I think HF had one on sale for a little over $100 a few weeks ago.
1994 Mazda Miata |
12-15-2013, 01:46 PM | #7 |
small pair of long nose needle nose pliers with a bend at the end? maybe. might find them at radio shack.
12-15-2013, 06:42 PM | #8 |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
I think removing the diff is going to be the way to go. By now the piece of plastic is probably floating in the oil. That would be very hard to get out through the fill plug hole.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray 480 RWHP 452 RWTQ + Nitrous Express 150 Shot |
12-15-2013, 06:46 PM | #9 |
i would try tho. altho it only takes A couple of hrs to get the diff out
12-16-2013, 01:25 AM | #10 |
Taeng
How long would it take the differential to chew it up?
12-16-2013, 09:08 AM | #11 |
Drives: Camaro SS & ZL1 Join Date: Sep 2011
Don't let your differential chew it like a piece of chewing gum.
Drain your differential. Remove the cover. Remove the plastic tube. Clean the contact surfaces and put a new gasket on there. Refill. Enjoy. |
12-16-2013, 07:42 PM | #12 |
They are just pulling your chain. Don't do this or you could run into even bigger problems. Your best option is to remove the differential like everyone else said. If you are unable or not comfortable with doing this then you should probably call a friend for help or tow it to the shop.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
