12-22-2013, 02:43 PM | #1 |
Drives: Camaro SS 2011 Join Date: Dec 2013
Why is this so cheap? Gear 3.91
Hello guys,
I would like to swap the rear gear ratio of my car. I was shopping around online and curious about the price difference I found for a 3.91 at about $289 and a 3.70 at $589! 3.91 at$289 http://www.phastekperformance.com/20...-gears-391.htm 3.70 at $589 http://www.phastekperformance.com/20...l380011410.htm Why would there be such a difference? Thank you very much Last edited by Jeffy14; 12-22-2013 at 02:54 PM. |
12-22-2013, 02:49 PM | #2 |
Drives: '14 1LE Join Date: Nov 2013
Not sure, but maybe it's because the GM 3.91 gear is used in a production car (SS/1LE) and more common?
12-22-2013, 02:51 PM | #3 |
Drives: 2SS/RS Join Date: Sep 2008
Laws of supply and demand.
The 3.91's are made by AAM for GM for use in the 1LE. GM buys more of a bulk and at one time than an individual company so they get sold to GM for less which results in lower prices for us. Also because GM sales more gears they also don't need as much as a profit per unit as other companies. |
12-22-2013, 02:56 PM | #4 |
OK guys thanks
So do you think it is worth it to take 3.91 i/o 3.70? I read somewhere that 3.91 or more could cause failure. Is that true? |
12-22-2013, 02:58 PM | #5 |
Depends on if you have an auto or manual. Generally I see 3.70 recommended for auto, and 3.91 recommended for manual.
I'm swapping out my 3.45 for a 3.91, based on the MANY positive recommendations from others on this site. I've yet to come across someone who regrets getting the 3.91 gear. |
12-22-2013, 03:00 PM | #6 | |
What do you have please? |
12-22-2013, 03:04 PM | #7 |
<--- It's in my signature. LS3 = manual (L99 = automatic).
I have a couple of threads in this forum where I tried to get feedback from the forum members regarding the 3.91 gear. You might want to search around for those or other similar discussions about the gear swap for the automatic. |
12-22-2013, 03:08 PM | #8 | |
I did not notice your signature I will look for your threads. PS: If that's your car, that's a nice once |
12-22-2013, 03:13 PM | #9 |
It is, thanks!
Here are a couple of threads from my research and opinion-seeking. http://www.camaro5.com/forums/showthread.php?t=331998 http://www.camaro5.com/forums/showthread.php?t=329619 |
12-22-2013, 06:55 PM | #10 | |
12-22-2013, 09:14 PM | #11 | |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
If you find a set, buy em. Even if you don't want em. They're worth their weight in Gold to somebody lookin for them. And 3.91s in an L99 is awesome BTW. Ivan |
12-22-2013, 09:33 PM | #12 |
Drives: 2010 Camaro SS Join Date: Oct 2013
Set on Ebay as we speak. Says there are 9 sets available actually.
http://www.ebay.com/itm/2010-2013-Ca...5a7840&vxp=mtr
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
12-23-2013, 08:06 AM | #13 |
OK guys thanks a lot so now the big question that have been asked over and over again.
Is 3.91 too much for automatic if I just have a tuning done and new cat back. Ivan seems to say this is fine? Even with what I have? People seem to say it will just tear tires etc.... The consensus is 3.73 for Automatic. Ivan what do you say please? |
12-23-2013, 02:46 PM | #14 |
Drives: Camaro SS Join Date: Jun 2013
3.91 gears not available in the usa?? I searched several sites, I came to buy and make payment in www.partstaxi.com, only that they canceled the purchase, said they do not have the product available, paid early, I'm expecting to return the money, still not returned. should put an availability before announcing. I want to buy oem gm 3.91 gears. but so far no availability. a friend called an authorized gm, and said that the gears do not have any prediction of availability
Thread Tools | |
