Old 04-06-2015, 04:46 PM   #1
Gavros 4 Life
Gavros 4 Life's Avatar
Drives: 2SS/RS Summit White Black Stripes
My supercharger belt split in half!?!? ECS kit
I was wondering if anyone can explain how my main supercharger belt on my ECS setup just split in half? Attached are some pics and a video. Furthermore, what type of belt can I get to replace it and where can I get one (autozone maybe?) thanks for the help just really confused how it happened because it doesn't seem like it rubbed on anything either.
2010 Camaro Supercharged L99 560RWHP/533TQ
(ECS) Novi 1500, Kooks LTH, Kooks High Flow cats, Ported TB, Barton Pistol Grip Shifter, QTP Cutouts, Borland Atak Catback, Llyods Matts, Complete Car Blackout w/ LS7 blackout, 35% Tints, ACS T5 splitter, ZTA Spoiler, White Powdercoated Calipers, 2 12" Kicker Subs & Amp, 20" TSW Valencias Satin Black on Vredestein Rubber, LED Footwells, LED Grill Strip, Custom Paddle Shifters, Dual Aerforce Gauges w/ Boost & Wideband, Heritage Grill, Pfadt Sway Bars, Pfadt Bushings, Granatelli Trailing Arms
Gavros 4 Life is offline   Reply With Quote
Old 04-06-2015, 04:48 PM   #2
Gavros 4 Life
More pics
Old 04-06-2015, 04:48 PM   #3
Gavros 4 Life
And another
Old 04-06-2015, 04:54 PM   #4
Frans96ss
Frans96ss's Avatar
Drives: 96SS
Had to be rubbing on something... Autozone or napa will have the belt.
Frans96ss is offline   Reply With Quote
Old 04-06-2015, 05:11 PM   #5
Gavros 4 Life
What size belt or specs of belt do I need? I believe it came with a NAPA belt just don't know the size or part number for the belt
Old 04-06-2015, 07:11 PM   #6
MA2010SS
Drives: 2010 Camaro SS
Check the belt path completely especially in the tensioner are being that's what moves when torque is applied
Take one half of the belt to an auto parts store and they can measure it for you they just need to know the rib count
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 04-06-2015, 08:14 PM   #7
Gavros 4 Life
Yea it was just the stock setup no pulley changes so need to figure out that size 8 or 10 rib? So how do I check though should I see what happens when I have someone rev the car? I sent the pics and video to ECS but no response back yet and I did bring the car down to them and they did a long once over and changed some things around to how their tec likes to have the setup positioned so I am surprised that something caused this. I just don't know how to tell what could hit it perfectly in the middle while in boost if that's the case of the tensioner? Maybe they didn't position it right? When idle it seems fine causes the bottom pulley to wiggle a little by the crank but I assume that's because there is half a belt on it.
Old 04-06-2015, 08:29 PM   #8
mbrusco103
mbrusco103's Avatar
Drives: 2011 2SS/RS (M6) 427 Twin Turbo
https://vimeo.com/124264028
Uploaded video for gavros
2011 Camaro 2SS/RS ERL 427 M6 TT
-AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler
mbrusco103 is offline   Reply With Quote
Old 04-06-2015, 11:35 PM   #9
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
Could be that something got in between the ribs and caused it to split or maybe just a defected belt. On my old setup I had one of the ribs on both crank and blower pulley scraped. Looked like it I sanded the paint off on just one rib and the belt was flawless.
DarkCry956 is offline   Reply With Quote
Old 04-07-2015, 06:38 AM   #10
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Mine has done it 3 times in the 3 years ive had it. Not really sure what causes it, cant see anything wrong. Autozone has them and one year warranty so ive got a couple for free.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 04-07-2015, 11:00 AM   #11
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
Maybe try white shoe polish on belt and run it for a few mins and see if there is any scraping on something...
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 04-07-2015, 04:27 PM   #12
blufin
blufin's Avatar
Drives: Fire Engine
I had the belt on my Maggie do the exact same thing. Turned out the tensioner was too loose and allowing the belt to jump around when getting off the throttle after full boost. After tightening it up, it hasn't happened since. IMO, I would start there and make sure the belt is as tight as possible.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 04-07-2015, 06:23 PM   #13
Gavros 4 Life
Thanks for the input guys belt should be here tomorrow got a Dayco 8 rib serpentine belt autozone didn't carry NAPA...is NAPA a better belt quality to go with or the Dayco will be good?
Old 04-07-2015, 06:39 PM   #14
Gavros 4 Life
If I ended up getting the wrong one, which I don't believe I did, can you guys send me some links to the exact belts needed for the ECS kit. I really would appreciate that also from other readings I might buy an extra and just keep it in the trunk.
