Old 05-22-2015, 07:53 AM   #1
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
Send a message via AIM to blake2010ss Send a message via MSN to blake2010ss
ECS supercharger, is this normal?
Here's a video i made a few weeks back of my supercharger making a rattling noise. The oil is full, and i cant see it vibrating against anything. It hasnt always made this noise. I have had it on for 11 months, its been making the sound for about 6. The supercharger seems like it still performs just fine, and I havent heard any others doing it.
thanks
2010 Camaro 2SS/RS LS3
1093/1066
416, AGP 6262, E85, Cam
blake2010ss is offline   Reply With Quote
Old 05-22-2015, 08:35 AM   #2
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Take the air filter off and make sure the restrictor plate is still intact and impeller is ok if u havent already.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 05-22-2015, 08:59 AM   #3
blake2010ss
Ill go check that in just a bit. would that cause any boost issues as far as spiking over where it should be or not building it? cause it seems like it still functions normal.
1093/1066
Old 05-22-2015, 10:00 AM   #4
pancherj
Drives: 2010 Camaro SS
The restrictor is two parts...a rolled ring (with a split) and a flat "washer". They are tack welded together and if mine is any indication...they are poor quality welds! I could easily believe yours has come apart.
pancherj is offline   Reply With Quote
Old 05-22-2015, 10:02 AM   #5
bct10985
Mine did come apart and tore up the impeller.
Old 05-22-2015, 10:12 AM   #6
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Send that video to ECS. They can tell you in a second.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-22-2015, 10:23 AM   #7
blake2010ss
took it apart and the ring was ok, but i didnt look at the washer. the impeller looks to be ok. one of the guys at my body shop looked at the tensioner pulley and noticed it didnt seem right, almost like a bearing was missing. said it sounds like metal to metal rattle from that pulley, almost may be causing wear on the other pulleys. Im not sure what to look for so ill post the pics he took.
1093/1066
Old 05-22-2015, 10:53 AM   #8
pancherj
The surface of my pulleys looks just like that (and I don't have that noise). It could be something internal to a pulley or idler.
Old 05-22-2015, 10:59 AM   #9
blake2010ss
I figured the pulleys were ok on the surface, i just wanted to double check with others. I do question if its that tensioner pulley though making the sound.
1093/1066
Old 05-22-2015, 12:30 PM   #10
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
Hate to be the bearer of bad news. Sounds exactly like mine did and had to be sent back for rebuild.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 05-22-2015, 12:45 PM   #11
blake2010ss
For no charge I hope
1093/1066
Old 05-22-2015, 01:51 PM   #12
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
I wish..it'll probably cost me more than the miles I have on it.
Build Thread
Old 05-22-2015, 01:55 PM   #13
blake2010ss
That's nuts. What did they determine was the cause
1093/1066
Old 05-22-2015, 02:00 PM   #14
Bo White
Bo White's Avatar
I have 60k miles on mine and this is always in the back of my mind lol.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
