03-08-2014, 08:21 PM | #1 |
Drives: 2016 Summit White Camaro 2SS Join Date: May 2009
Anywhere Local to Install Skip Shift Eliminator?
Has anyone in lower eastern MI found a place to install a skip shift eliminator?
03-08-2014, 08:38 PM | #2 |
Too much is never enough!
any shop can do it it. all you do is raise the car and pull the plug and install the new one and your done!
if you have a two jack stands and a jack you can do it in no time
03-08-2014, 08:48 PM | #3 |
03-11-2014, 03:25 PM | #4 |
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28 Join Date: Nov 2011
MY DEALER installed mine Along with my Hurst short throw shifter
03-14-2014, 08:39 AM | #5 |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
Where are you located.....I may be willing to help on a weekend. It is super easy.
-Matt
03-14-2014, 05:32 PM | #6 |
03-15-2014, 01:37 PM | #7 | |
Do you already have the part?
03-15-2014, 03:15 PM | #8 |
If you don't want your dealer to do it or they won't, go to a trans shop. 10mins & $25 is what it cost me.
03-15-2014, 08:26 PM | #9 |
No, I have not ordered one yet. I appreciate the offer but with the drive out there, I may just call up my dealership to see if they would do it.
03-15-2014, 08:27 PM | #10 |
03-15-2014, 09:12 PM | #11 |
Drives: 2013 1LE Join Date: May 2013
