06-26-2023, 02:23 PM | #1 |
Drives: 2023 Camaro Convertible 2LT Join Date: May 2023
Mods Lowering Performance?
I read some comments on YouTube videos about simple mods like a cold air intake, and how performance actually suffers after this sort of an upgrade. Is that true, and if it is, why would we want to even attempt performance upgrades?
06-26-2023, 03:50 PM | #2 | |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Be realistic about what your goals are and work with a good shop and/or tuner who can help you make it happen.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
07-17-2023, 08:45 PM | #3 | |
I'm talking specifically about the 2.0L Turbo, which is never going to make 1000 HP unless you redefine what HP is LOL. Someone was mentioning that even a K&N cold air intake actually lowered the performance of their 2.0L Turbo... that's unexpected for me. |
07-17-2023, 08:57 PM | #4 | |
07-17-2023, 10:04 PM | #5 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
Mods on newer GM cars can actually slow the car down if you don't tune correctly for them. You have to increase the torque limits in the tune or the throttle closes X amount to stay under Y preset torque limit.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
07-17-2023, 10:16 PM | #6 | |
Drives: 6th Gen LT1 Join Date: Jun 2023
Plus the OEM system already has a cold air intake. F1 cars use air filter for the same reason. The easiest way to test is just to remove the air filter and drive the car. If no difference is noticed, a "performance" filter will do less than that. |
09-02-2023, 06:28 AM | #7 | |||
I bought the car for the Sharkskin Metallic paint, Shock and Steel package, and the convertible (it's amazing how fast the top goes up and down). I'm surprised at the performance of the engine. I thought it was going to be a slow downer, but it has plenty of pep for me. |
09-02-2023, 06:42 PM | #8 |
Drives: 2021 camaro 1ls Join Date: Nov 2020
Check out the Chevrolet web site for accessories that will not void your warranty. The lowering kit will improve handling but not acceleration.
09-03-2023, 06:34 AM | #9 |
In the past, I had a Corvette C6 with the Z51 handling package. Obviously, that car had an amazing ride. The ride improved even more when replaced the Goodyear Eagle run-flats with Regular all-season tires (economical Nitto tires). I can't replace the new run-flats on this Camaro in good conscience, but I can say I'll be happy when they are worn down. If it's 2, 3, or 4, years into ownership, replacing these run-flats will bring a breath of fresh air to the Camaro's ride that I am actively anticipating. The Camaro handles great, much closer to the feel of the Corvette than my last 3 daily-driver SUVs.
09-05-2023, 07:59 AM | #10 | |
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP Join Date: Jan 2016
The air filter business is tricky, because a filter has a performance curve which changes over its life. Initially it is very porous and free-flowing. In mid-life it has a "dirt plug" which actually improves filtration with limited impact on flow. Late life it is more clogged, and will impede flow, mostly at very high flow rates. |
09-29-2023, 01:23 PM | #11 |
Drives: 2023 Camaro 1LT V6 Join Date: Jul 2023
It's not only the mod. When your engine was built play a roll, not to question GM QC. But I'd rather have one built on a we'd than a Friday lol. I have a 23' V6 small mods. But very very enjoyable.
