01-20-2014, 08:38 PM | #1 |
Drives: 2012 Camaro ZL1, 2000 Silverado LT Join Date: Dec 2013
Oil Pressure Question
Does anyone else's gauges read like these?
After about 2 hours of run time cruising at about 2200 rpm (sorry it's a blurry) Idling after being ran for about 2 hours. I have not hooked up my gauge to the computer to get the reading from there. I know these gauges from what I've read don't read accurately. Thanks
v/r
Roger 2012 ZL-1 #1076 2016 Explorer XLT (wife's) 2002 Ducati ST4S 2000 Silverado LT 1995 Triumph Daytona 1200 |
01-20-2014, 08:43 PM | #2 |
Drives: '21 ZLE A10 Join Date: May 2012
mine is almost exactly like those readings....if you rev +500-1000rpm the oil pressure should go up quickly. A tick less than 30psi at idle is nothing to worry about.
01-20-2014, 10:00 PM | #3 |
Cartoon Maus
Drives: White ZL1, Chevroyota Prizolla Join Date: Aug 2013
The one on the lower right is reading WAY too low.
01-20-2014, 10:51 PM | #4 |
BAD ZL1
Drives: 2013 VIN 48 Victory Red ZL1! Join Date: Jan 2012
01-20-2014, 11:19 PM | #5 |
Drives: 2013 Camaro ZL1 Join Date: Oct 2012
You should hook up a scanner and check. The oil gauge lies. You'll be in the mid 20s idling hot, 30+ normal, and 40+ cold, and should be 40+ after 2000 rpm. Oil pressure will drop the hotter the car is, so take that into account. Any doubts at all, have the dealer check it. Mine dropped by only 10psi from normal and I have a new engine now.
