BORLA
Old 12-20-2017, 02:34 PM   #1
2ndHump
Drives: FrostBite
Tires
So the stock sizing of the tires are 285/35-20-front and 305/35-20-rear..... If you aren’t using stock sizing on your Zs what are you all using? Can I go from a 305 to a 315 on the back without any changes to anything else and be okay?
Thanks
2ndHump is offline   Reply With Quote
Old 12-20-2017, 03:04 PM   #2
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
Dropping the profile size is generally a bad idea unless you increase the width. If you do this you are looking at a shorter tire height. This was keep you lower to the ground but also change gearing/speedo. Going from a 305 to a 315 isn't a huge jump. I wouldn't worry so much about that.
GET MORE POWER PER DOLLAR!!!
We carry all the hottest brands for your Gen5 and Gen6 Camaros! Get awesome deals on Corsa, SLP, ARH, SW, Whipple, Kooks, Procharger, CAI, K&N, Rtoto-Fab and much more! Call us for your CAMARO5 discount today!
224-63-JUICE OR INFO@JUICEDMOTORSPORTS.COM
Juiced1 is offline   Reply With Quote
Old 12-20-2017, 03:18 PM   #3
SquawkVFR
Once upon a time...
SquawkVFR's Avatar
Drives: 2010 Camaro
Not only is 305 to 315 ok, it’s mo bettah and safer.
#76,458 of 129,405. Fancy floor mats, AC, painted lug nuts, high thingy on the back, thingy in the receptacle, low thingy on the front, loud thingy in the middle, open/closer doohickies, sucker uppers and castle back smoke stack super jet.
SquawkVFR is offline   Reply With Quote
Old 12-20-2017, 03:48 PM   #4
GONMAD510
Drives: 2013 ZL1 M6
The ride will be a little rougher with less sidewall but it may not be a big deal.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP
630.35 RWTQ
GONMAD510 is offline   Reply With Quote
Old 12-20-2017, 03:55 PM   #5
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2010 X5 Camaro Turbo
We have had several customers run the 275/35/20 fronts and 315/35/20 rears on the ZL1/1LE wheels without any issues.
Sales@Phastek is offline   Reply With Quote
Old 12-20-2017, 04:56 PM   #6
zman1969
zman1969's Avatar
Drives: 1969 R/S Z28 302 m20 Endura
I have 295/35 and 315/35 Nitto invo's on mine and I like them- alot!
no issues with fitment
1969 RS Z/28 302
1969 Firebird LS6-6 speed TA clone
2015 Zl1
zman1969 is offline   Reply With Quote
Old 12-20-2017, 05:45 PM   #7
silversleeper
Some ol' dude
silversleeper's Avatar
Drives: '13 ZL1
Your wife has been complaining you spend too much time on the computer. I just sent her back home so it's time you pretend you've been cutting the grass today.
Edit: To the OP 315 rears ! Less chance of curb rash too.
silversleeper is offline   Reply With Quote
Old 12-20-2017, 06:06 PM   #8
SquawkVFR
Once upon a time...
SquawkVFR's Avatar
Drives: 2010 Camaro
If only that were true.....lol
Old 12-21-2017, 12:10 PM   #9
OPntop12
OPntop12's Avatar
Drives: 2013 Camaro ZL1 Convertible
I have that setup. No problems
OPntop12 is offline   Reply With Quote
Old 12-21-2017, 01:34 PM   #10
JB'sZL1
Drives: 2013 ZL1
Ditto. I just installed 315 rears and love 'em! The hook much better (almost all the time in my climate) and look sick.
JB'sZL1 is offline   Reply With Quote
Old 12-21-2017, 02:17 PM   #11
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
The ZL1 understeers as delivered by the factory. Adding 315s to the rear increases the understeer. It is all good in a straight-line and not so good if you like to carve corners. It all depends on how you use her.
Old 01-06-2018, 09:44 PM   #12
2ndHump
Drives: FrostBite
So I can fit 295 35 20 on my front with no issues .. no additional work?
Old 01-08-2018, 06:53 PM   #13
cowmaro
Drives: 2012 M6 ZL1
335 rear fits but is sloppy handling
315 is good....also is a sport SUV size and easier/cheaper to find.
cowmaro is offline   Reply With Quote
Old 01-10-2018, 11:07 AM   #14
DRKS1D3
DRKS1D3's Avatar
Drives: 2011 Camaro SS Convertible LS3
Go to TireRack.com, enter your vehicle, it will provide you with stock sizes and tires that are produced in said sizes. Don't put an SUV tire on a 580hp pony car. It's an easy process. Good luck!
MY RIDE: 2011 TRIPLE BLACK SS CONVERTIBLE (BOUGHT NEW 4-2011)--6 SPEED MANUAL, K&N TYPHOON INTAKE, FLOWMASTER FORCE II MUFFLERS, HOTCHKIS SUSPENSION, BLACKED OUT BOWTIES, GLOSS BLACK 20x9 STYLE 41 WHEELS, 285-35-20 GOODYEAR EAGLE SUPERCAR G2'S, JBA HIGH-FLOW CATS, BBK HEADERS, LUNATI CUSTOM GRIND CAM: 227/235 .619/.626 114 +3
DAD'S RIDE: 2012 ZL1 #1866 (BOUGHT NEW 6-2012)--BLACK, 6 SPEED, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE
"Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!".
DRKS1D3 is offline   Reply With Quote
