07-04-2014, 10:51 PM | #1 |
Drives: IOM Camaro 2SS Join Date: Apr 2010
Help!
Ok so I have spent the last few days installing a new pair of headers on my 2010 SS. After three days of work I finally started the car this evening. After running for a few seconds the car began to lose rpms and began to slow. I did this twice, the second time I checked the spark plug wires to make sure they were well connected. Any suggestions of what I might try next?
07-04-2014, 11:02 PM | #2 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Did you remove the spark plugs for the install? Most issues seem to be cracked spark plugs, if they weren't removed.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
07-04-2014, 11:06 PM | #3 |
No, I did not remove them. Did not realize they were that delicate. Any suggestion on a replacement brand? I see E3 advertised a lot but Ive heard mixed reviews about them.
07-04-2014, 11:56 PM | #4 |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
Use stock plugs. No real benefit in changing them given your config.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
07-05-2014, 12:16 AM | #5 |
Alright, thanks for the advice
07-05-2014, 08:54 AM | #6 |
Search Ninja
Stock plugs for sure unless you're boosted or running nitrous.
E3's are junk.
07-06-2014, 09:17 PM | #7 |
Ok, so I got the plugs all changed. The rpm's are holding steady but what rpm should I be at? I think its hovering around 6 or 7 hundred. That seems really low. Is that right?
07-06-2014, 09:23 PM | #8 |
Drives: 2013 AGM 1SS/RS LS3 Join Date: Mar 2011
That rpm actually seems high for a stock tune. Should be around 550-600.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts |
07-06-2014, 09:29 PM | #9 |
Oh alright. This is my first time doing headers or messing with the exhaust at all so I had no idea what to expect. Thanks though
07-06-2014, 10:57 PM | #10 |
Search Ninja
If you're not tuned, it may take a little bit for the PCM to adjust to the headers. No worries though. Does the car drive ok now?
07-07-2014, 12:52 AM | #11 |
I took it out for a little spin earlier tonight. Got on it a bit and it seems to be working just fine. Rechecked the rpm's and they're sitting right at 600. I was under the impression that I wouldn't need a tune for these. Seems like a waste to pay for a tune now when more upgrades will be coming.
07-07-2014, 01:52 AM | #12 | |
Drives: SIM, 2SS/RS, LS3 Join Date: Mar 2010
2SS/RS - SIM Naked
Born on February 8, 2010 ADM Street CAI, Flowmaster AT, VMax, SCT Tuner with a Jannetty Tune |
07-07-2014, 07:36 AM | #13 | |
07-07-2014, 11:25 AM | #14 |
I have shorty headers not LT's so does that make a difference regarding needing a tune? Just trying to make sure Im not wasting money by getting a tune that won't do much in the long run. Especially because I may switch too LT's eventually. I only bought the shorties because I got a great deal on a pair of used ones from my friend.
