01-31-2015, 07:24 PM | #1 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
Heater core lines
Ok stupid quick question. I'm planning a swap of those ugly hoses that go up over the head and intake with a zl1 version. My question is do I have to drain the radiator or will it be ok to just pull the lines and lose what's in the hoses.
01-31-2015, 07:48 PM | #2 |
Drives: 2012 2SS 6 speed CRMT Join Date: Oct 2014
Don't know for sure but recall seeing DYI on it. Might try search on this forum. It is in the DYI section hearer hose relocation, believe caverman posted it.
Me and Boomer |
01-31-2015, 07:54 PM | #3 |
Svt lol
Ok I'll give it a look. I just assumed I thought oil/fluids that might be a good place to start.
01-31-2015, 11:29 PM | #4 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
I did't when I did my 2010 SS, but I used the 2011 SS set up and not the ZL1 set up.
02-01-2015, 04:57 PM | #5 |
Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
You'll lose about a gallon of anti-freeze. Take off the old hose at the heater core end first and let the coolant drain into a bucket.
02-01-2015, 05:30 PM | #6 |
Drives: 2011 Camaro SS/M6 Join Date: Dec 2013
Nope just pull them off. Like mentioned above you'll lose about a gallon
2011 Ls3. Slp TSV2300. 8PSI. 3.4 Pulley. Livernois Twin Fuel Pump. Id850 Injectors. Slp 1 3/4 headers. CAI Cold Air Intake. 3inch exhaust. V-Maxx portted throttle body. Night Fury cam. Lpe 391 gears. Fj performence tune. 643rwhp 574rwtq
02-02-2015, 06:57 AM | #7 |
Svt lol
Appreciate the info guys I'll get it done this weekend.
02-02-2015, 08:30 AM | #8 |
Drives: 2010 2SS Join Date: Sep 2012
probly get some air in the system then tho right? im about to do the same mod.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
02-02-2015, 11:20 AM | #9 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Drained from radiator into clean container. Needed to cut hoses. Would not slide off of heater core.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
