12-29-2014, 05:52 AM | #1 |
Drives: 2011 White 2SS Join Date: May 2011
Convertible storage
When storing a convertible is it best to store it with the top up or down?
Also would it be better to store up and not latch it? Thanks Sent from my iPhone using Tapatalk |
12-29-2014, 07:34 AM | #2 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
Up
Why wouldn't you latch it? Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
12-29-2014, 07:53 AM | #3 |
Didn't know if it would be better for the top material not to be stretched that last bit when you latch it.
12-29-2014, 08:27 AM | #4 |
709 RWHP & 677 RWTQ
Drives: 13' HPE 800 ZL1..... IOM vert, M6 Join Date: Feb 2013
My thought too. I don't latch it. Don't know if that is correct or not.
11.34 @ 124.88
12-29-2014, 08:31 AM | #5 |
Drives: '11 VR 2LT HHr Join Date: May 2011
I had a Cavalier ( i know the material and such are different but), i left the top down for several months.
It was jammed and wouldnt come all the way closed ( latched) When i got it fixed in the spring there was a good 2 inch gap or more. My Vote is Up and Latched all winter long ! guess you could say treat your top as if it was a coupe and help keep out un wanted winter residents ! or is that rodents
2011 Hhr
Formerly known as Silver85IrocZ !! |
12-29-2014, 08:54 AM | #6 |
It's under a cover in heated garage so no rodents inside but my 4yr old. (Hopefully lol)
12-29-2014, 05:36 PM | #7 |
Drives: 2012 1SS Camaro Convertible Join Date: Sep 2010
Every convertible I have had since 87 has always been stored with the top up and latched and the windows cracked a 1/2 inch. That way the air can flow through the interior and no moisture will accumulate.
2012 1SS Crystal Red Convertible
"Cherry Bomb" Winner of the #NameThatCamaro Spring Special Edition "Green Flash" |
12-29-2014, 06:54 PM | #8 |
Drives: 2015 1LE Suspen 2SS RS Green Flash Join Date: Jul 2013
Got mine last year in April and only had the top down a few times and stored with it up latched.
Same this year with the windows up and covered. Heated garage so not worried about critters getting in and making a home.
SCJ NPP LS3 RGU B7J 5W8 KYU KTU WRS GM3 UV6 SLN NAV Bray-Krause Harness Bar Race Quip 6 point Harnesses
12-29-2014, 07:19 PM | #9 |
Good idea about windows being cracked a little bit.
12-29-2014, 08:20 PM | #10 |
Drives: 2011 2SS/RS Vert Join Date: Mar 2013
Windows cracked a bit. May be good idea?
Going to give that a try now.
2011 2SS/RS VERT
Moroso Catch Can,K&N CAI,Apex Air Scoop & Washer Relocate,ZL1 Grille,GTO Clutch Rez, Frameless 2013 mirror. Tuned by MGS Performance |
12-29-2014, 08:29 PM | #11 |
Drives: 2013 Black 2 LT vert Join Date: Jul 2013
i would never leave a vert top down more than 2 or 3 days max. before i bought mine, i called Haartz directly and they said no more than 3 days. so, leave the top up, and latched and i would probably clean it good and apply eithe 303 or Ragg top. keep a lint bruch handy too.
12-31-2014, 08:18 AM | #12 |
Drives: 2014 2SS/RS Convertible - sold Join Date: Jul 2014
Up and latched is never an issue but down causes all kinds of things like sunburn, windburn, rain showers, extreme smiles, etc....
01-02-2015, 05:33 PM | #13 |
If your worried about moisture in your garage let me suggest this
I keep a few of these in the garage. They are inexpensive and do collect moisture. They also sell different sizes Ryan
Ryan
