08-11-2021, 11:46 AM | #1 |
Drives: 2010 IOM 2ss/RS Join Date: Sep 2009
ok i need more help, hard start when hot!
i will tell you what i have done... replaced starter 2x, now has NEW HTQ starter, along with new pigtail and new crank sensor. the starter is heat wrapped. i have cleaned the neg battery cable in trunk, i have added a postive bypass cable past the post in the engine bay. i have added ground wire to the engine/frame. the battery has been replaced a couple times. is it possible its in the tune? is there anywhere else i should add a ground? i am going to add heat wrap to the exhaust where it passes the starter as well. but i am soooooooooooo tired of this!!!!
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
08-11-2021, 12:52 PM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
There were some post a couple of years ago with some tune tweaks that were supposed to help. I don't remember anymore details but if you dig you can likely find the post or maybe someone else can remember more details.
08-11-2021, 03:17 PM | #3 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
It has to do with ignition timing when the vehicle is in hot start vs cold start. Minor tun adjustment should help with that
