05-04-2015, 12:26 PM | #1 |
Drives: 2010 SS/RS L99 Join Date: May 2013
RX Catch Can L99 Install help
Just wanted to make sure I got the lines right.
Any feedback is greatly appreciated |
05-04-2015, 01:49 PM | #2 |
everything looks good.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
05-04-2015, 03:43 PM | #3 |
Awesome Thanks
05-04-2015, 08:43 PM | #4 |
Drives: 1LE Join Date: Feb 2013
Anyone else think it a bitch to get the hoses on the barbs? I was so paranoid I didn't get them slipped on far enough, I used hose clamps.
05-04-2015, 09:21 PM | #5 |
GEN5 Detail
Drives: 2011 Synergy Series 2SS Convertible Join Date: Sep 2014
That's why I bought the braided hose that had the fittings already attached, made things a lot easier and was worth the extra cost.
Roto-Fab CAI, Borla ATAK Exhaust System, Stainless Power Headers, RX Performance Catch Can, ACS T4 Splitter, Oracle side markers, Dyno Tuned by RDP Motorsports
05-05-2015, 05:34 AM | #6 |
I have the braided lines too. But, you still need to connect them as normal at the intake/crankcase, and getting them on was a bear. I also had to replace the check valve, so I had the added challenge of getting the braided lines over the new valve's barbs.
As a matter of a fact, I assumed it was worse for the braided, since the nylon would naturally resist the rubber when it tried to expand. I got it on . . . with a heat gun. Added the clamps for piece of mind. |
05-05-2015, 10:14 AM | #7 |
I had more difficulty getting the factory pcv line off then the putting the new hose on the barbs. Took me a bit to figure out how to undo the clips.
05-05-2015, 11:41 AM | #8 |
The new hose was a little hard to slide on so I think its tight enough, but I'm gonna put a couple clamps on today just to be sure.
The whole install was much easier than I thought. After reading the install instructions from RX I was confused with all the cutting but again Camaro5 saves me. Thanks guys |
Thread Tools | |
