sjm autoprod
Old 10-26-2017, 03:59 PM   #1
Scotty D
Drives: 2014 1le 1SS CRMT
315/35/20s ??
Thinking about switching from my 295/35/20 to 315/35/20 ?!?! Is it going to be a huge difference ? Or will I even Notice it??
Thanks
Scotty D is offline   Reply With Quote
Old 10-26-2017, 09:52 PM   #2
Scotty D
Nobody ?
Old 10-26-2017, 09:59 PM   #3
charles71
charles71's Avatar
Drives: 2011 Camaro SS
You will notice it but depending on the brand of tire you buy some run wider than others
Livernois Stage II Heads & Cam, LS7 Lifters, Ported Intake & Throttle Body, Rotofab CAI, BBK High Flow Fuel Rail @ Guage, Eaton Tru Trac Posi with 3.91 gears, 1200 HP Axels, Kooks Long tubes & full Corsa Exhaust, GM Hurst Short Throw Shifter, Mcleod Twin Disc, Vitesse Throttle Controller, 1.25" Lowering Springs, Strut Tower Brace, SLP 25% Underdrive Pulley, Apex reservoir relocation kit and air scoop.
charles71 is offline   Reply With Quote
Old 10-26-2017, 10:11 PM   #4
Scotty D
Was going to do Nitto invos again
Old 10-26-2017, 10:11 PM   #5
CCMADONNA
CCMADONNA's Avatar
Drives: 2014 SW 2SS/RS
i definitely felt more badass when I went from 275 to 305.
It looked way better too!
2014 2SS/RS VERT L99
SUMMIT WHITE
AIRAID CAI
BORLA ATAK CAT-BACK EXHAUST
ELITE ENGINEERING CATCH-CAN
RANGE AFM-DELETE MODULE
HUPER OPTIK 40
CHROME PEDALS
PREMIUM FLOOR MATS
PREMIUM CARGO MAT
DEDICATED 32GB iPHONE HD
[/I][/B][IMG][/IMG]
CCMADONNA is offline   Reply With Quote
Old 10-27-2017, 02:05 AM   #6
Notilloc
Notilloc's Avatar
Drives: 2015 Chevy Camaro SS 1LE
You probably won't feel a difference and I'm guessing you're talking about rear tire only so the only difference you'll feel is in the corners and unless you love understeer it won't be a good difference. Are you having an issue with tire spin?
Notilloc is offline   Reply With Quote
Old 10-27-2017, 09:07 AM   #7
Billy10mm
Billy10mm's Avatar
Drives: 2014 Camaro 2SS 1LE NPP
1LE forum. It's the track package. I, and many others, have spent good money trying to remove understeer. You are deliberately adding more. But, as a half-glass full kinda person, I can see the upside. Upside being that you'll have less back pain when you're 70 because your wallet will be lighter from the more expensive tires you get to buy.
So it's a toss really. Good luck on the decision.
My thoughts on some things:
  • Driving Nannies: If I'm that far out of shape on the street, something has gone terribly wrong and by all means Mr. Computer man, come and get me.
  • G2s: Rock throwing is like like a tramp stamp; although problematic, it's a sign of good things to come.
Billy10mm is offline   Reply With Quote
Old 10-27-2017, 09:18 AM   #8
acammer
Back in the game
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Agree with the thought above - the square stance is you best bet for keeping understeer in check. If you just wanna drag race and need as much tire under the back as possible, then it's fine, but it will negatively impact the cornering balance of the car. Just gotta decide what's important to you, I know folks doing it both ways, and happy with their choices.
FWIW I have spent some time with a 1LE car that migrated to a 275/315 setup. It certainly didn't have a gross imbalance, but it definitely tightened the car up on the limit. I run a square 275 setup on my SS, and even with stock chassis tuning the car is noticeably much closer to neutral than with a stock 245/275 configuration.
2011 Camaro 2SS SGM - American Racing Headers/X-pipe and cats, cutouts behind the axle, Cold Air Inductions CAI, New Era Ported TB, 169* T-stat, Ideal Garage clutch master cylinder and remote reservoir, 4.10 gears. 412rwhp. 12.59@113.4mph.
acammer is offline   Reply With Quote
Old 10-27-2017, 10:03 AM   #9
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
Be nice Billy....be nice!
gajagfan is offline   Reply With Quote
Old 10-27-2017, 10:45 AM   #10
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
What's your goal, Scotty? I've considered staying square, because I don't want to affect the cars balance on the track, but maybe going 295 or 305 all around...
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 10-27-2017, 01:13 PM   #11
Billy10mm
Billy10mm's Avatar
It was an attempt at humor. That said, I'm not a comedian, and it shows really.
Old 10-27-2017, 01:24 PM   #12
1LEJNG
Drives: Red Hot 2014 1LE
315s
Thanks
I did it with MPSS. No difference, only street drive.
Was hoping for better straight line traction and I like the way they look.
1LEJNG is offline   Reply With Quote
Old 10-27-2017, 05:22 PM   #13
Gstick
Drives: 2015 Camaro SS/RS 1LE
I think that the comment about the wallet was hillarious.
Just curious tho, what kind of handling effect would happen if I were to run 295/35/20's on all 4 corners of my 1LE ? I understand that our OEM 285/35/20's are 27.9" tall, and the 295/35/20's are 28.1" tall, but will this change anything other than a slight difference in gear ratio ?
Thanks !
Gstick is offline   Reply With Quote
Old 10-27-2017, 06:44 PM   #14
Notilloc
Notilloc's Avatar
Thanks !
Nope, you won't feel a difference at all.
