Emblempros
Old 11-19-2017, 08:53 PM   #1
SS Performance
Drives: 02 Camaro B4C
Rear brake calipers
So I was looking at the rear brake calipers for my 2015 1LE. I was shocked at the price $911!!!!!
So my question is are the Z06 rear calipers the same (I want to stay red). The Z06 rears are $288.
A man's garage is his castle
1970 Camaro SS
2002 Camaro B4C
2015 Camaro 1SS 1LE
SS Performance is offline   Reply With Quote
Old 11-19-2017, 10:57 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS and Twin Turbo'd SRT8
Have you checked eBay should be a lot cheaper there and yes the rears are the same but not sure between the Z06/GS and the Z51s. I know the front Z06/GS steel rotor 6 piston caliper are the same as CTS-V and ZL1. Check over at www.corvetteforum.com might be able to get a good deal.
Orange Krush II
1LE Front with DSE Links and Rear Sway Bars, Splitter, 3.91 Gears with 1LE Axles, 14/15 Heat extractor in a 13 1LE hood, 1LE shocks and struts,1LE Suede Flat bottom Steering wheel restitched in orange, Factory Hurst short throw shifter with the Pegasus rear poly shifter mount, ZL1 Rockers, Belly Pan and pedals, Z/28 Intake, Skip Shift eliminator, 1LE diffuser with dual mode mufflers, Z/28 headers and Cats, 1 piece DSS Drive Shaft, C7 Z06 Vented Piston Calipers and CTS-V Rotors, PAFDT Solid Cradle bushing, Z/28 Toe Rods and UCA Bushings.
Old 11-21-2017, 08:11 PM   #3
SS Performance
Anyone?
1970 Camaro SS
2002 Camaro B4C
2015 Camaro 1SS 1LE
Old 11-23-2017, 10:01 PM   #4
wakespeak
wakespeak's Avatar
Drives: 2013 2SS LS3/NPP
I think the Z06/CTS-V/ZL1/SS rears are all same.
NPP, 1LE track pack, ZL1/1LE shifter, Apex catch can, 1LE oil separator, Goodridge stainless steel brake lines,1LE strut tower brace. Wheels: 19x10 front and 19x11 rear w/1LE offsets. Pegasus Aluminum Rear Cradle Bushings. Z/28 upper control arm bushings.
wakespeak is offline   Reply With Quote
Old 12-07-2017, 04:11 AM   #5
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
Be very aware of counterfeit parts that look like GM parts but aren’t. There’s a whole business around selling this stuff.
Sent from my iPad using Tapatalk Pro
2013 1LE NPP GBE
Mods
Track Days
CrystalRedTintcoat is offline   Reply With Quote
Old 12-07-2017, 07:03 AM   #6
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 2LT/RS
I think your best bet would be to find a complete used set of Brembo calipers, which you can get now days for about $400.00-$450.00, then send them to TPH Coatings where it will cost, if I recall correctly, $350.00 for the powder coating, all new seals and postage.
You should be able to do this for about $800.00 for front and rear!
Deputy347k9 is offline   Reply With Quote
Old 12-10-2017, 02:46 PM   #7
SS Performance
I found a set red set (1LE) on ebay that are on the way.
The Corvette rears don't fit our cars. I ordered a set and tried them. No joy.
1970 Camaro SS
2002 Camaro B4C
2015 Camaro 1SS 1LE
